Beats Solo 3 Battery Replacement
  1. Beats Solo 3 Battery Replacement, Battery: step 1, image 1 of 2 Beats Solo 3 Battery Replacement, Battery: step 1, image 2 of 2
    • Pry off the outside pane on the right side of the headphone with an opening tool.
  2. Beats Solo 3 Battery Replacement: step 2, image 1 of 1
    • You should see your battery here. It will be square with yellow packaging.
    • Be sure not to pull on the wires that are connected to the outside panel. This may cause damage to your headphones.
  3. Beats Solo 3 Battery Replacement: step 3, image 1 of 2 Beats Solo 3 Battery Replacement: step 3, image 2 of 2
    Tool used on this step:
    Buy
    • Grasp the battery's small bundled connector, and pull gently to remove.
    • Carefully remove the top attachment from the headphones with tweezers or your fingers.
  4. Beats Solo 3 Battery Replacement: step 4, image 1 of 2 Beats Solo 3 Battery Replacement: step 4, image 2 of 2
    • Use an opening tool or a nylon spudger to carefully remove the battery. Make sure you pry upward.
    • Do not bend or puncture the lithium-ion battery.
    • Once that is removed, make sure you peel off the sticker where the battery is placed if it stuck to the battery.
    • If it is, then place it back where it belongs in the headphones.
3 other people completed this guide.
One Comment
Where too buy battery?
GSD - Reply
Past 24 Hours: 23
Past 7 Days: 125
Past 30 Days: 590
All Time: 12,762
