Beats Solo 3 Headband Replacement
  1. Beats Solo 3 Headband Replacement, Headband: step 1, image 1 of 3 Beats Solo 3 Headband Replacement, Headband: step 1, image 2 of 3 Beats Solo 3 Headband Replacement, Headband: step 1, image 3 of 3
    • Carefully partially remove the headband cushion cover. Be careful not to rip the two headband eyelets just above the screws on each end of the headband.
  2. Beats Solo 3 Headband Replacement: step 2, image 1 of 2 Beats Solo 3 Headband Replacement: step 2, image 2 of 2
    • With the main part of the cover off, pull the head band cover up and out of the metal headband ends, exposing the screws underneath.
  3. Beats Solo 3 Headband Replacement: step 3, image 1 of 3 Beats Solo 3 Headband Replacement: step 3, image 2 of 3 Beats Solo 3 Headband Replacement: step 3, image 3 of 3
    • Unscrew all four 1.4 mm screws on the right and left ends on the underside of the headband using a T5 Torx screwdriver.
  4. Beats Solo 3 Headband Replacement: step 4, image 1 of 1
    • Pull the metal headband end out from the headband slightly, and disconnect the rubber band from the hook.
  5. Beats Solo 3 Headband Replacement: step 5, image 1 of 2 Beats Solo 3 Headband Replacement: step 5, image 2 of 2
    • Remove the inner headband by gently prying the edges and corners.
  6. Beats Solo 3 Headband Replacement: step 6, image 1 of 1
    • Carefully peel up the glued wire in the headband.
  7. Beats Solo 3 Headband Replacement: step 7, image 1 of 1
    • Pull the headband out of the slots gently.
  8. Beats Solo 3 Headband Replacement: step 8, image 1 of 1
    • Put the new headband into the slots carefully.
4 other people completed this guide.
Joseph Konadu
211 Reputation
1 Guide authored
2 Comments
help when i was putting on the new headband the snap on middle parts fell out and i cant put them back in (the metal connection parts)
koro - Reply
same it happen to me as well
Bardo -
Past 24 Hours: 3
Past 7 Days: 49
Past 30 Days: 212
All Time: 11,361
