Beats Solo Pro Side panel Replacement
  1. Beats Solo Pro Side panel Replacement, Extending the Headphones: step 1, image 1 of 2 Beats Solo Pro Side panel Replacement, Extending the Headphones: step 1, image 2 of 2
    • Slide the headphones down to extend the hinge.
  2. Beats Solo Pro Side panel Replacement, Prying off the side panel: step 2, image 1 of 2 Beats Solo Pro Side panel Replacement, Prying off the side panel: step 2, image 2 of 2
    • Once extended insert a prying the new gap to unclip the panel
    • Once unclipped repeat on the other side of the panel
    • The two clips are towards the top of the panel, as indicated by the location of the metal prying tool in the image.
  3. Beats Solo Pro Side panel Replacement, Sliding out the side panel: step 3, image 1 of 2 Beats Solo Pro Side panel Replacement, Sliding out the side panel: step 3, image 2 of 2
    • Slide the panel down and lift away from the headphone just until its separated
    • Don't pull the plastic piece offs there is still cables attached to it
  4. Beats Solo Pro Side panel Replacement, Tightening or replacing: step 4, image 1 of 2 Beats Solo Pro Side panel Replacement, Tightening or replacing: step 4, image 2 of 2
    • If needed tighten the PH00 screw(if your side panel has came loose on it own you will need to do this to fix the issue)
    • If you want to replace the side panel you will need to carefully pry the cables out from where they are glued in and glue them in to the new panel(refer to second image)
To reassemble complete steps in reverse:-)
4 other people completed this guide.
HelloMacOS
26,143 Reputation
11 Guides authored
Repair is War on Entropy Member of Repair is War on Entropy
Community
27 Members
1,209 Guides authored
One Comment
Muchas gracias por tus pasos a seguir.
Yo tengo un problema pero con el tornillo que esta tapado por los cables, al cual no puedo acceder para poderlo apretar contra la tapa exterior.
Alfredo Olvera - Reply
Past 24 Hours: 7
Past 7 Days: 25
Past 30 Days: 108
All Time: 3,225
