Beats Studio 2 Wireless Battery Replacement
  1. Beats Studio 2 Wireless Battery Replacement, Battery: step 1, image 1 of 2 Beats Studio 2 Wireless Battery Replacement, Battery: step 1, image 2 of 2
    • Using a spudger, remove the panel circling the ‘b’ Beats logo on the right earphone by applying pressure upwards under the panel until it is removed.
  2. Beats Studio 2 Wireless Battery Replacement: step 2, image 1 of 2 Beats Studio 2 Wireless Battery Replacement: step 2, image 2 of 2
    • Remove the four screws securing the housing with a Phillips #00 screwdriver.
  3. Beats Studio 2 Wireless Battery Replacement: step 3, image 1 of 1
    • Use a spudger to release the clip in the seam under the silver “studio” label.
    • Remove the right side of the headband.
  4. Beats Studio 2 Wireless Battery Replacement: step 4, image 1 of 1
    • Gently remove the right earphone speaker from the headband by sliding the speaker downwards.
  5. Beats Studio 2 Wireless Battery Replacement: step 5, image 1 of 3 Beats Studio 2 Wireless Battery Replacement: step 5, image 2 of 3 Beats Studio 2 Wireless Battery Replacement: step 5, image 3 of 3
    • Use the pointed tip of a spudger to carefully push on each side of the connector to release it from the socket on the motherboard.
    • Be gentle with the connectors as they can break easily.
    • Don't use a metal spudger to remove a battery or any internal component. This is potentially dangerous as it could puncture the battery and cause a fire or worse.
    • Use a nylon spudger to remove the battery from the headphones.
5 other people completed this guide.
Jack Wilson
581 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 42
Past 30 Days: 206
All Time: 5,387
