Beboncool Gamepad for Nintendo Switch Battery Replacement
  1. Beboncool Gamepad for Nintendo Switch Battery Replacement, Beboncool Nintendo Switch Gamepad Disassembly: step 1, image 1 of 3 Beboncool Gamepad for Nintendo Switch Battery Replacement, Beboncool Nintendo Switch Gamepad Disassembly: step 1, image 2 of 3 Beboncool Gamepad for Nintendo Switch Battery Replacement, Beboncool Nintendo Switch Gamepad Disassembly: step 1, image 3 of 3
    • Use the plastic opening tool to remove the blue plastic grips from the sides of the controller.
  2. Beboncool Gamepad for Nintendo Switch Battery Replacement: step 2, image 1 of 2 Beboncool Gamepad for Nintendo Switch Battery Replacement: step 2, image 2 of 2
    • Use the Phillips #0 screwdriver to remove the seven 5mm screws from the back of the controller.
  3. Beboncool Gamepad for Nintendo Switch Battery Replacement: step 3, image 1 of 3 Beboncool Gamepad for Nintendo Switch Battery Replacement: step 3, image 2 of 3 Beboncool Gamepad for Nintendo Switch Battery Replacement: step 3, image 3 of 3
    • Gently separate the two halves of the controller.
    • As the two covers come apart the L1 and R1 button, will fall free from the controller. Be sure not to lose them if they should pop out and fall.
    • Be sure to slide the small circuit boards out of the covers to be able to separate the two halves
  4. Beboncool Gamepad for Nintendo Switch Battery Replacement: step 4, image 1 of 2 Beboncool Gamepad for Nintendo Switch Battery Replacement: step 4, image 2 of 2
    • Use the Phillips #0 screwdriver to remove the two 3.5mm screws holding the circuit board in place.
  5. Beboncool Gamepad for Nintendo Switch Battery Replacement: step 5, image 1 of 3 Beboncool Gamepad for Nintendo Switch Battery Replacement: step 5, image 2 of 3 Beboncool Gamepad for Nintendo Switch Battery Replacement: step 5, image 3 of 3
    • Lift the motherboard from the back case with the vibration motors and button boards attached.
  6. Beboncool Gamepad for Nintendo Switch Battery Replacement, Battery: step 6, image 1 of 3 Beboncool Gamepad for Nintendo Switch Battery Replacement, Battery: step 6, image 2 of 3 Beboncool Gamepad for Nintendo Switch Battery Replacement, Battery: step 6, image 3 of 3
    • Carefully separate the battery which is adhered to the circuit board.
  7. Beboncool Gamepad for Nintendo Switch Battery Replacement: step 7, image 1 of 3 Beboncool Gamepad for Nintendo Switch Battery Replacement: step 7, image 2 of 3 Beboncool Gamepad for Nintendo Switch Battery Replacement: step 7, image 3 of 3
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 21
All Time: 594
