Behringer BCD3000 Disassembly
  1. Behringer BCD3000 Disassembly, Behringer BCD3000 Disassembly: step 1, image 1 of 1
    • Unplug from all cables
  2. Behringer BCD3000 Disassembly, opening the sides: step 2, image 1 of 2 Behringer BCD3000 Disassembly, opening the sides: step 2, image 2 of 2
    • unscrew two Phillips screws on each side of the BCD3000
    • If the screws sit too tight, you can use the extension for better torque
  3. Behringer BCD3000 Disassembly, loosening the top part: step 3, image 1 of 2 Behringer BCD3000 Disassembly, loosening the top part: step 3, image 2 of 2
    • unscrew another two Phillips screws on each side
  4. Behringer BCD3000 Disassembly: step 4, image 1 of 3 Behringer BCD3000 Disassembly: step 4, image 2 of 3 Behringer BCD3000 Disassembly: step 4, image 3 of 3
    • Lift the upper control part.
    • Be careful, there are still some cables connected to the lower section.
    • Disconnect the cables by walking them out of their sockets.
  5. Behringer BCD3000 Disassembly: step 5, image 1 of 1
    • Remove the upper part completely.
  6. Behringer BCD3000 Disassembly: step 6, image 1 of 1
    • Disconnect the two cables from the lower section to the connector board.
  7. Behringer BCD3000 Disassembly: step 7, image 1 of 3 Behringer BCD3000 Disassembly: step 7, image 2 of 3 Behringer BCD3000 Disassembly: step 7, image 3 of 3
    • Slide the lower section to the front.
    • Now you can lift it and take it aside.
  8. Behringer BCD3000 Disassembly: step 8, image 1 of 3 Behringer BCD3000 Disassembly: step 8, image 2 of 3 Behringer BCD3000 Disassembly: step 8, image 3 of 3
    • Disconnect the separate boards.
    • Now you can take the modules out by unscrewing them from the case.
  9. Behringer BCD3000 Disassembly: step 9, image 1 of 2 Behringer BCD3000 Disassembly: step 9, image 2 of 2
    • The jog wheels on the front panel can be taken off by using a spudger and levering them out.
  10. Behringer BCD3000 Disassembly: step 10, image 1 of 2 Behringer BCD3000 Disassembly: step 10, image 2 of 2
    • The knobs can easy be removed just by pulling.
  11. Behringer BCD3000 Disassembly: step 11, image 1 of 3 Behringer BCD3000 Disassembly: step 11, image 2 of 3 Behringer BCD3000 Disassembly: step 11, image 3 of 3
    • Same goes for the knobs on the top section of the front panel.
6 other people completed this guide.
Tobias Isakeit
129,751 Reputation
189 Guides authored
4 Guide Comments
Pensaba que serviría para la BCD2000… pero es algo distinta.
Antonio - Reply
great stuff, with better quality pictures would be better
csipapicsa - Reply
This is great! I thought it would be like the other BC controllers (BCR/BCF2000) with a clip on the side panels. I need to re-seat my knob rings that have gotten loose and fallen of the top panel.
NomeX - Reply
Thanks for the guide! I was able to re-glue and re-seat my knob rings that popped loose. I had two on the top section (main vol and FX4) and one at the lower that was working loose, so I decided to hit that one as well since I already had the BDC3000 apart. I find it odd that Behringer used machine screws on the bottom of the machine since they screw into plastic posts. The control knobs rings are held in place with a thin glue that, after nearly 20 years (mine was 1105 date), have weakened and allow easy popping off. I used a glue that didn't melt the pieces together (preferred, but I didn't have), so I may have to go through this process again. When reassembling, take care that the buttons seat properly into the panels as they can wiggle out of place and make screwing the PCBs difficult and reassembly impossible. If you need total disassembly, you'll need a socket wrench or mini pliers to remove the nut from the headphone jack. I don't think this is a necessary step if you're just re-seating/gluing the rings.
NomeX - Reply
Past 24 Hours: 3
Past 7 Days: 13
Past 30 Days: 54
All Time: 3,194
