Beiens Cartoon RC Race Car LED Light Replacement
  1. Beiens Cartoon RC Race Car LED Light Replacement, LED Light: step 1, image 1 of 1
    • Hold the remote control with the backside facing you and, using the Phillips #00 screwdriver, unscrew the six 6.5 mm screws on the back of the controller that hold it together.
  2. Beiens Cartoon RC Race Car LED Light Replacement: step 2, image 1 of 1
    • Open the remote control.
  3. Beiens Cartoon RC Race Car LED Light Replacement: step 3, image 1 of 1
    • Lift the motherboard to separate it from the remote control.
  4. Beiens Cartoon RC Race Car LED Light Replacement: step 4, image 1 of 1
    • To remove the light, use a soldering iron to heat the solder to a liquid and loosen the leads.
    • While the solder is liquid, lightly pull on the LED to remove it from the motherboard.
    • The soldering iron will get very hot while it's in use. Be sure to place it on top of a heat protected surface and be careful not to touch the operational end.
Amber Ashley
329 Reputation
4 Guides authored
USF Tampa, Team 1-6, Leahy Fall 2015 Member of USF Tampa, Team 1-6, Leahy Fall 2015
USFT-LEAHY-F15S1G6
3 Members
8 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 9
All Time: 291
