Belkin F5L114 Battery Replacement
  1. Belkin F5L114 Battery Replacement, Battery: step 1, image 1 of 3 Belkin F5L114 Battery Replacement, Battery: step 1, image 2 of 3 Belkin F5L114 Battery Replacement, Battery: step 1, image 3 of 3
    • Switch the power button that is located at the bottom left of the keyboard to Off.
  2. Belkin F5L114 Battery Replacement: step 2, image 1 of 2 Belkin F5L114 Battery Replacement: step 2, image 2 of 2
    • Flip the keyboard over.
  3. Belkin F5L114 Battery Replacement: step 3, image 1 of 3 Belkin F5L114 Battery Replacement: step 3, image 2 of 3 Belkin F5L114 Battery Replacement: step 3, image 3 of 3
    • Pull back gently on the left side of the bottom-left rubber foot enough to expose the small screw.
  4. Belkin F5L114 Battery Replacement: step 4, image 1 of 1
    • Use a Phillips #0 screwdriver to unscrew the screw.
    • The screw may not come fully out of the device.
  5. Belkin F5L114 Battery Replacement: step 5, image 1 of 1
    • Pull back gently on the bottom left corner of the middle rubber foot enough to expose the small screw.
  6. Belkin F5L114 Battery Replacement: step 6, image 1 of 1
  7. Belkin F5L114 Battery Replacement: step 7, image 1 of 2 Belkin F5L114 Battery Replacement: step 7, image 2 of 2
    • Pull back gently on the right side of the bottom-right rubber enough to expose the small screw.
  8. Belkin F5L114 Battery Replacement: step 8, image 1 of 1
  9. Belkin F5L114 Battery Replacement: step 9, image 1 of 2 Belkin F5L114 Battery Replacement: step 9, image 2 of 2
    • Insert the spudger into the space next to the right screw area.
    • Gently pry open the battery case.
  10. Belkin F5L114 Battery Replacement: step 10, image 1 of 3 Belkin F5L114 Battery Replacement: step 10, image 2 of 3 Belkin F5L114 Battery Replacement: step 10, image 3 of 3
    • Gently pry the battery cover off.
  11. Belkin F5L114 Battery Replacement: step 11, image 1 of 2 Belkin F5L114 Battery Replacement: step 11, image 2 of 2
    • Remove the battery cover.
    • Locate the battery.
  12. Belkin F5L114 Battery Replacement: step 12, image 1 of 2 Belkin F5L114 Battery Replacement: step 12, image 2 of 2
    • Lift the battery up using the spudger.
    • The battery is taped down.
  13. Belkin F5L114 Battery Replacement: step 13, image 1 of 3 Belkin F5L114 Battery Replacement: step 13, image 2 of 3 Belkin F5L114 Battery Replacement: step 13, image 3 of 3
    Tool used on this step:
    Buy
    • Gently unplug the battery from the motherboard using the tweezers.
    • Remove the battery.
One Comment
Hi, I would like buy another battery for my keyboard. May you help me please?
Rundy Henry - Reply
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 45
All Time: 772
