Belkin NetCam HD Microphone Replacement
  1. Belkin NetCam HD Microphone Replacement, Case: step 1, image 1 of 1
    • Use a wrench to loosen up the stand from the back in order to hold the NetCam more comfortably.
  2. Belkin NetCam HD Microphone Replacement: step 2, image 1 of 1
    • Work a plastic opening tool into the seam and pry the face plate away from the back panel.
  3. Belkin NetCam HD Microphone Replacement: step 3, image 1 of 2 Belkin NetCam HD Microphone Replacement: step 3, image 2 of 2
    • Use pressure to separate the covers.
    • When pulling the device apart, separate from the bottom up in order to avoid pulling the wiring at the top apart.
  4. Belkin NetCam HD Microphone Replacement, Microphone: step 4, image 1 of 2 Belkin NetCam HD Microphone Replacement, Microphone: step 4, image 2 of 2
    Tool used on this step:
    Buy
    • Use tweezers to gently pull out the white attachment from the port.
    • Use your fingers to pull out the white attachment from the tan port on the front of the board a little.
  5. Belkin NetCam HD Microphone Replacement: step 5, image 1 of 2 Belkin NetCam HD Microphone Replacement: step 5, image 2 of 2
    • Use a pair of tweezers to wedge between the mic and the rubber guard to remove the mic from the front cover.
    • If the rubber guard comes off with the mic just remove the guard from mic and place back on the front cover.
Destinie DiazVerdejo
805 Reputation
7 Guides authored
USF Tampa, Team 3-5, Sullivan Fall 2016 Member of USF Tampa, Team 3-5, Sullivan Fall 2016
USFT-SULLIVAN-F16S3G5
4 Members
14 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 24
All Time: 503
