Belkin NetCam HD Plus Front Casing Replacement
  1. Belkin NetCam HD Plus Front Casing Replacement, Case: step 1, image 1 of 1
    • Use a wrench to loosen up the stand from the back in order to hold the NetCam more comfortably.
  2. Belkin NetCam HD Plus Front Casing Replacement: step 2, image 1 of 1
    • Work a plastic opening tool into the seam and pry the face plate away from the back panel.
  3. Belkin NetCam HD Plus Front Casing Replacement: step 3, image 1 of 2 Belkin NetCam HD Plus Front Casing Replacement: step 3, image 2 of 2
    • Use pressure to separate the covers.
    • When pulling the device apart, separate from the bottom up in order to avoid pulling the wiring at the top apart.
  4. Belkin NetCam HD Plus Front Casing Replacement, Microphone: step 4, image 1 of 2 Belkin NetCam HD Plus Front Casing Replacement, Microphone: step 4, image 2 of 2
    Tool used on this step:
    Buy
    • Use tweezers to gently pull out the white attachment from the port.
    • Use your fingers to pull out the white attachment from the tan port on the front of the board a little.
  5. Belkin NetCam HD Plus Front Casing Replacement: step 5, image 1 of 2 Belkin NetCam HD Plus Front Casing Replacement: step 5, image 2 of 2
    • Use a pair of tweezers to wedge between the mic and the rubber guard to remove the mic from the front cover.
    • If the rubber guard comes off with the mic just remove the guard from mic and place back on the front cover.
  6. Belkin NetCam HD Plus Front Casing Replacement, Front Casing: step 6, image 1 of 1
    • Carefully use your fingers to gently pull out the white attachment from the tan colored part.
Destinie DiazVerdejo
805 Reputation
7 Guides authored
USF Tampa, Team 3-5, Sullivan Fall 2016 Member of USF Tampa, Team 3-5, Sullivan Fall 2016
USFT-SULLIVAN-F16S3G5
4 Members
14 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 10
All Time: 432
