Belkin WeMo Light Switch Replacement
  1. Belkin WeMo Light Switch Replacement, Switch: step 1, image 1 of 1
    • Open up your breaker box.
    • Breaker boxes are commonly located in garages, basements, or on a wall on the outside of the house.
    • Turn off the breaker that corresponds to the circuit your WeMo Light Switch is connected to.
  2. Belkin WeMo Light Switch Replacement: step 2, image 1 of 2 Belkin WeMo Light Switch Replacement: step 2, image 2 of 2
    • Once you have ensured the power to the circuit is disconnected, you may continue with the disassembly.
    • Remove the faceplate of the light switch by prying it off with a flathead screwdriver. The plate should come off if lightly pried.
  3. Belkin WeMo Light Switch Replacement: step 3, image 1 of 3 Belkin WeMo Light Switch Replacement: step 3, image 2 of 3 Belkin WeMo Light Switch Replacement: step 3, image 3 of 3
    • Using a Phillips #0 screwdriver, remove the two screws on the top and bottom of the switch.
    • Pull out the switch from the wall to reveal its connections.
  4. Belkin WeMo Light Switch Replacement: step 4, image 1 of 2 Belkin WeMo Light Switch Replacement: step 4, image 2 of 2
    • Remove the caps from the light switch's connected wires, and detach the switch from the wall.
    • The green ground wire may be held in place by a screw. Use your flathead screwdriver to loosen the screw and remove the wire.
  5. Belkin WeMo Light Switch Replacement: step 5, image 1 of 1
    • Once the removal process is complete, you may install a new light switch.
Kevin Ho
121 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 22
All Time: 1,606
