Bell and Howell DNV16HDZ LED Replacement
  1. Bell and Howell DNV16HDZ LED Replacement, Lens Assembly: step 1, image 1 of 2 Bell and Howell DNV16HDZ LED Replacement, Lens Assembly: step 1, image 2 of 2
    • Remove the five 30mm Phillips #0 screws on the bottom of the camera.
  2. Bell and Howell DNV16HDZ LED Replacement: step 2, image 1 of 1
    • Use a plastic opening tool to disconnect the internal hinges that snaps the camera into place.
    • Using a plastic opening tool is important since a metal one will scratch or damage the thin plastic hinges that hold the camera together.
  3. Bell and Howell DNV16HDZ LED Replacement: step 3, image 1 of 1
    • It will still be connected by a plastic film. This can also be disconnected by pulling up the white part where it connects to the light circuit board.
  4. Bell and Howell DNV16HDZ LED Replacement, LED: step 4, image 1 of 1
    • Take out the two 20 mm Phillips #0 screws that attach it to the shutter.
  5. Bell and Howell DNV16HDZ LED Replacement: step 5, image 1 of 3 Bell and Howell DNV16HDZ LED Replacement: step 5, image 2 of 3 Bell and Howell DNV16HDZ LED Replacement: step 5, image 3 of 3
    • The two 30 mm Phillips #0 screws left can be removed to gain access to the circuit board along with the LED.
    • From here we can pop out the LED using the wedge or your fingers if you can manage it.
Donald Desrosier
101 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 10
All Time: 313
