Bella 4-Slice Toaster Oven Temperature Dial Replacement
  1. Bella 4-Slice Toaster Oven Temperature Dial Replacement, Outer Shell: step 1, image 1 of 1
    • Remove five 11.6 mm Phillips #2 screws from the rear of the device.
  2. Bella 4-Slice Toaster Oven Temperature Dial Replacement: step 2, image 1 of 1
    • Open the front glass door of the toaster oven.
  3. Bella 4-Slice Toaster Oven Temperature Dial Replacement: step 3, image 1 of 1
    • Locate retaining screw on the upper-middle portion of the door frame.
  4. Bella 4-Slice Toaster Oven Temperature Dial Replacement: step 4, image 1 of 1
    • Remove one 21.9 mm Phillips #2 retaining screw from upper-middle portion of door frame.
  5. Bella 4-Slice Toaster Oven Temperature Dial Replacement: step 5, image 1 of 1
    • Flip toaster onto back panel with feet facing forward.
  6. Bella 4-Slice Toaster Oven Temperature Dial Replacement: step 6, image 1 of 1
    • Use spudger to pry the grey rubber inserts from the black plastic feet.
  7. Bella 4-Slice Toaster Oven Temperature Dial Replacement: step 7, image 1 of 1
    • Remove four 13.7mm Phillips #2 screws from black plastic feet to separate the cover from the device.
  8. Bella 4-Slice Toaster Oven Temperature Dial Replacement: step 8, image 1 of 1
    • Lift the black outer cover off of the toaster
  9. Bella 4-Slice Toaster Oven Temperature Dial Replacement, Temperature Dial: step 9, image 1 of 1
    • Using a plastic spudger, gently pry the black plastic temperature dial away from the face of the toaster.
  10. Bella 4-Slice Toaster Oven Temperature Dial Replacement: step 10, image 1 of 1
    • Remove two 5.91 mm #2 Phillips screws which secure the inner component to the toaster.
  11. Bella 4-Slice Toaster Oven Temperature Dial Replacement: step 11, image 1 of 1
    • Inside the device, unplug the red wire connecting the black plastic part of the dial to the heating element.
  12. Bella 4-Slice Toaster Oven Temperature Dial Replacement: step 12, image 1 of 1
    • Now unplug the other red wire from the black plastic part of the dial.
  13. Bella 4-Slice Toaster Oven Temperature Dial Replacement: step 13, image 1 of 1
    • Unplug the two white wires from the metal part of the dial.
  14. Bella 4-Slice Toaster Oven Temperature Dial Replacement: step 14, image 1 of 1
    • Remove the dial from device interior.
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 10
All Time: 419
