Bella TXG-FS075A Heating Element Replacement
  1. Bella TXG-FS075A Heating Element Replacement, Heating Element: step 1, image 1 of 3 Bella TXG-FS075A Heating Element Replacement, Heating Element: step 1, image 2 of 3 Bella TXG-FS075A Heating Element Replacement, Heating Element: step 1, image 3 of 3
    • Use a spudger to pry off the metal top of the air fryer.
  2. Bella TXG-FS075A Heating Element Replacement: step 2, image 1 of 2 Bella TXG-FS075A Heating Element Replacement: step 2, image 2 of 2
    • Use an iFixit opening tool to pry off the plastic frame.
  3. Bella TXG-FS075A Heating Element Replacement: step 3, image 1 of 3 Bella TXG-FS075A Heating Element Replacement: step 3, image 2 of 3 Bella TXG-FS075A Heating Element Replacement: step 3, image 3 of 3
    • Remove the four 13 mm screws from the second plastic frame using a Phillips #2 screwdriver.
    • Pry off the black plastic frame.
  4. Bella TXG-FS075A Heating Element Replacement: step 4, image 1 of 1
    • Remove the two 13 mm screws using a Phillips #2 screwdriver.
  5. Bella TXG-FS075A Heating Element Replacement: step 5, image 1 of 3 Bella TXG-FS075A Heating Element Replacement: step 5, image 2 of 3 Bella TXG-FS075A Heating Element Replacement: step 5, image 3 of 3
    • Using a spudger, pry off the outer frame.
    • Pull up on the outer frame, exposing the inner wall of the fryer.
  6. Bella TXG-FS075A Heating Element Replacement: step 6, image 1 of 2 Bella TXG-FS075A Heating Element Replacement: step 6, image 2 of 2
    • Remove the 13 mm screw connecting to the heating element's bracket using a Phillips #2 screwdriver.
  7. Bella TXG-FS075A Heating Element Replacement: step 7, image 1 of 2 Bella TXG-FS075A Heating Element Replacement: step 7, image 2 of 2
    • Pull out the heating element.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 39
All Time: 754
