Belt Loop Keeper Replacement
  1. Belt Loop Keeper Replacement, Belt Loop Keeper: step 1, image 1 of 2 Belt Loop Keeper Replacement, Belt Loop Keeper: step 1, image 2 of 2
    • Measure the pieces of leather so the resulting strap will wrap around with a width of 0.5 in and a 1 cm overlap.
  2. Belt Loop Keeper Replacement: step 2, image 1 of 2 Belt Loop Keeper Replacement: step 2, image 2 of 2
    • Mark the measurements with an indent.
    • Our belt was 1.5 in wide; the leather strap we measured was 4 x 0.5 in.
    • Cut the leather strap using scissors or a pocket knife.
    • Caution: Hazardous situation which, if not avoided, could result in minor or moderate injury.
  3. Belt Loop Keeper Replacement: step 3, image 1 of 2 Belt Loop Keeper Replacement: step 3, image 2 of 2
    • Wrap the leather strap around the belt with 1 cm of overlap.
    • Mark the area underneath where the leather piece will overlap to center the eyelet.
  4. Belt Loop Keeper Replacement: step 4, image 1 of 1
    • Place an eyelet on the inner flat side of the eyelet pliers.
  5. Belt Loop Keeper Replacement: step 5, image 1 of 2 Belt Loop Keeper Replacement: step 5, image 2 of 2
    • Placing the loop of leather in between the pliers, center the eyelet on the indent previously made and press down firmly.
    • Use a hammer to strike the outside of the pliers for additional force.
  6. Belt Loop Keeper Replacement: step 6, image 1 of 3 Belt Loop Keeper Replacement: step 6, image 2 of 3 Belt Loop Keeper Replacement: step 6, image 3 of 3
    • Make sure both sides of the leather loop are secured.
    • Insert the belt tail into the leather loop.
    • Slide down the desired belt.
  7. Belt Loop Keeper Replacement: step 7, image 1 of 2 Belt Loop Keeper Replacement: step 7, image 2 of 2
    • Buckle the belt and insert the excess belt material into the belt loop keeper.
    • Adjust until satisfied.
Finish Line
2 other people completed this guide.
Shel Rivas
193 Reputation
1 Guide authored
UC Davis, Team 3-1, Vidal-Chiesa Fall 2024 Member of UC Davis, Team 3-1, Vidal-Chiesa Fall 2024
UCD-VIDAL-CHIESA-F24S3G1
3 Members
2 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 35
Past 30 Days: 146
All Time: 1,410
