Benchmade Griptillian Disassembly
  1. Benchmade Griptillian Disassembly, Close the blade and turn the knife to the side that has the belt clip: step 1, image 1 of 1
    • Be sure to make note of what side the belt clip is on for reassembly.
  2. Benchmade Griptillian Disassembly, Remove screws: step 2, image 1 of 1
    • Use a T6 bit to remove the two screws holding the belt clip.
  3. Benchmade Griptillian Disassembly, Remove T6 Screws: step 3, image 1 of 1
    • Use the T6 bit to remove the four screws holding the handle in place.
  4. Benchmade Griptillian Disassembly, Turn the knife over: step 4, image 1 of 1
    • Turn the knife over and remove one T6 screw.
  5. Benchmade Griptillian Disassembly, Remove the T8 screw: step 5, image 1 of 1
    • Turn the knife over and remove the T8 screw that is going through the hinge.
  6. Benchmade Griptillian Disassembly, Remove the handle: step 6, image 1 of 1
    • Once you've removed the screw, you can remove the handle.
  7. Benchmade Griptillian Disassembly, Drive pin out of the other handle: step 7, image 1 of 1
    • Using the T6 bit, drive the hinge pin out of the other handle.
  8. Benchmade Griptillian Disassembly, Remove the other handle: step 8, image 1 of 1
    • Once you've done this you can remove the other handle.
  9. Benchmade Griptillian Disassembly, Slide the blade out of the frame: step 9, image 1 of 1
    • Be sure to keep both brass washers. Sometimes they will stick to the frame or the blade.
  10. Benchmade Griptillian Disassembly, Sand both sides of copper: step 10, image 1 of 1
    • Using 600 grit sandpaper and a flat surface, rub both sides of the copper washers until there is new material showing.
  11. Benchmade Griptillian Disassembly, Reverse process to re assemble: step 11, image 1 of 1
    • Reverse process to re assemble.
3 other people completed this guide.
Spin Modder
256 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 65
All Time: 1,080
