Benq FP71G+ LCD Monitor Disassembly
  1. Benq FP71G+ LCD Monitor Disassembly, Remove the screws holding the base: step 1, image 1 of 1
    • Remove the screws holding the base.
  2. Benq FP71G+ LCD Monitor Disassembly, Slide out the base: step 2, image 1 of 1
    • Slide out the base
  3. Benq FP71G+ LCD Monitor Disassembly, Remove the screws holding the back cover of the screen: step 3, image 1 of 1
    • Remove the screws holding the back cover of the screen.
  4. Benq FP71G+ LCD Monitor Disassembly, Remove the back cover: step 4, image 1 of 3 Benq FP71G+ LCD Monitor Disassembly, Remove the back cover: step 4, image 2 of 3 Benq FP71G+ LCD Monitor Disassembly, Remove the back cover: step 4, image 3 of 3
    • Start by prying out the back cover using a screwdriver in the holes at the bottom.
    • Continue along the bottom edge
    • Then follow by the side edges all the way to the top
  5. Benq FP71G+ LCD Monitor Disassembly, Disconnect control panel and remove VGA connector screws: step 5, image 1 of 1
    • The VGA connector screws shouldn't be too hard to unscrew, if you don't have the appropriate 5 mm wrench, you can use a set of pliers.
  6. Benq FP71G+ LCD Monitor Disassembly, Slide back the logic board cover: step 6, image 1 of 1
    • Just slide it down. No need to remove the tinfoil sticker.
  7. Benq FP71G+ LCD Monitor Disassembly, Proceed as you wish with the logic board: step 7, image 1 of 1
    • If the screen is not working, you may want to look for and replace any blown capacitors.
    • In my case, the two 1000 uF, 16 V electrolytes at the top right were faulty.
Michael Konečný
172 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 26
All Time: 6,897
