Bernina 350 PE L-Board D5 Capacitor Replacement
  1. Bernina 350 PE L-Board D5 Capacitor Replacement, Loosen and Remove L-Board Screw: step 1, image 1 of 3 Bernina 350 PE L-Board D5 Capacitor Replacement, Loosen and Remove L-Board Screw: step 1, image 2 of 3 Bernina 350 PE L-Board D5 Capacitor Replacement, Loosen and Remove L-Board Screw: step 1, image 3 of 3
    • Remove the sewing machine's L-Board by removing this screw with a Torx T-20 driver.
  2. Bernina 350 PE L-Board D5 Capacitor Replacement, Detach L-Board Cable and Remove L-Board: step 2, image 1 of 3 Bernina 350 PE L-Board D5 Capacitor Replacement, Detach L-Board Cable and Remove L-Board: step 2, image 2 of 3 Bernina 350 PE L-Board D5 Capacitor Replacement, Detach L-Board Cable and Remove L-Board: step 2, image 3 of 3
    • Place fingers above and beyond Bear Quilting Patch and pull l-board gently toward you.
    • Rotate left side of l-board toward you and to the right to access cable.
    • Gently remove yellow cable.
  3. Bernina 350 PE L-Board D5 Capacitor Replacement, Remove L-Board's Cover: step 3, image 1 of 2 Bernina 350 PE L-Board D5 Capacitor Replacement, Remove L-Board's Cover: step 3, image 2 of 2
    • Remove 4 screws with Torx T-10 driver.
    • Foreground is the base, pull it toward you and cover (background/closest to table) stays behind.
    • Base, with l-board attached, is shown in last picture.
  4. Bernina 350 PE L-Board D5 Capacitor Replacement, Examine L-Board Capacitors: step 4, image 1 of 3 Bernina 350 PE L-Board D5 Capacitor Replacement, Examine L-Board Capacitors: step 4, image 2 of 3 Bernina 350 PE L-Board D5 Capacitor Replacement, Examine L-Board Capacitors: step 4, image 3 of 3
    • Capacitor attached to D5 is bulging out the top and is pushing its innards out the bottom.
    • If damaged like the one in photograph, obtain a replacement capacitor for D5 that is rated for long-life, 25 volts, and 100 µF, I found one at MicroCenter for $0.99.
  5. Tool used on this step:
    Buy
    • I used a soldering gun to and wick to remove as much solder from back side of board where D5 is marked.
    • After solder is removed, I gently bent the capacitors pins so they were straightened and ready to remove from hole.
    • Adding flux to the board, heated the pins and use a tweezers to pull on the D5 capacitor.
  6. Bernina 350 PE L-Board D5 Capacitor Replacement, Install Replacement Capacitor: step 6, image 1 of 3 Bernina 350 PE L-Board D5 Capacitor Replacement, Install Replacement Capacitor: step 6, image 2 of 3 Bernina 350 PE L-Board D5 Capacitor Replacement, Install Replacement Capacitor: step 6, image 3 of 3
    • Slide the replacement capacitor into the D5 board holes.
    • Heat the board and apply solder.
    • Replacement capacitor looks like pictures to the left.
  7. Bernina 350 PE L-Board D5 Capacitor Replacement: step 7, image 1 of 1
    • Replace cover on l-board and reinsert 4 screws.
    • Gently place extra slack from yellow l-board cable back inside sewing machine body.
    • In reverse, return to Step 2, complete, and conclude with Step 1 to continue reassembling sewing machine and test.
To reassemble your device, follow these instructions in reverse order beginning with Step 2.
NorthernBigDummy
612 Reputation
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 24
All Time: 159
