Beyblade LR String Launcher Fix
  1. Beyblade LR String Launcher Fix, Beyblade LR String Launcher Fix: step 1, image 1 of 2 Beyblade LR String Launcher Fix, Beyblade LR String Launcher Fix: step 1, image 2 of 2
    • Use a Phillips #00 screwdriver to remove five screws from the bottom of the launcher.
  2. Beyblade LR String Launcher Fix: step 2, image 1 of 1
    • Use a spudger to pry the cover off exposing the gear that houses the string.
  3. Beyblade LR String Launcher Fix: step 3, image 1 of 2 Beyblade LR String Launcher Fix: step 3, image 2 of 2
    • Unravel the string from the gear.
    • Remove the gear that was housing the string.
  4. Beyblade LR String Launcher Fix: step 4, image 1 of 2 Beyblade LR String Launcher Fix: step 4, image 2 of 2
    • Use a flathead screwdriver to rotate the slot on the front of the gear counterclockwise 9-10 times.
  5. Beyblade LR String Launcher Fix: step 5, image 1 of 2 Beyblade LR String Launcher Fix: step 5, image 2 of 2
    • Keep the flathead screwdriver in the slot.
    • Place the gear back in the socket with the slot perpendicular.
    • Carefully remove the flathead screwdriver.
    • Push on the slot to recall the string.
  6. Beyblade LR String Launcher Fix: step 6, image 1 of 3 Beyblade LR String Launcher Fix: step 6, image 2 of 3 Beyblade LR String Launcher Fix: step 6, image 3 of 3
    • Put the cover back on the string launcher.
    • Use a Phillips #00 screwdriver to replace the five screws that secure the cover.
To reassemble, follow these instructions in reverse order.
3 other people completed this guide.
Thomas Wong
352 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 40
Past 30 Days: 105
All Time: 1,715
