Bike Chain Installation
  1. Bike Chain Installation, Bike Chain Installation: step 1, image 1 of 2 Bike Chain Installation, Bike Chain Installation: step 1, image 2 of 2
    • Rout the chain around the front chain rings and rear derailleur.
    • Pull the ends of the chain together.
  2. Bike Chain Installation: step 2, image 1 of 2 Bike Chain Installation: step 2, image 2 of 2
    • Use the chain cutter tool to press the chain pin back through the chain link. If it is difficult to push it back in, the links are not aligned properly. Realign and try again if this is the case.
    • Caution: Reusing pins in chains can cause the chain to fail. This is because the pins are press fit into link. Using a new pin when assembling a chain is recommend for long term use.
Finish Line
3 other people completed this guide.
aaron thielk
1,942 Reputation
5 Guides authored
Cal Poly, Team 5-13, Maness Fall 2010 Member of Cal Poly, Team 5-13, Maness Fall 2010
CPSU-MANESS-F10S5G13
4 Members
19 Guides authored
2 Guide Comments
what do you do if the Chain keeps Falling off when your Riding the Bike an the Chain still rubs against the tire .
Anthony - Reply
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 33
All Time: 16,928
