Billy Goat Brush Cutter BC2600HHF 2015 Transaxle Drive Belt Replacement
  1. Billy Goat Brush Cutter BC2600HHF 2015 Transaxle Drive Belt Replacement, Spark Plug Disconnection: step 1, image 1 of 2 Billy Goat Brush Cutter BC2600HHF 2015 Transaxle Drive Belt Replacement, Spark Plug Disconnection: step 1, image 2 of 2
    • Grab the plastic housing at the end of the spark plug wire.
    • Pull firmly to disconnect the wire from the spark plug.
  2. Billy Goat Brush Cutter BC2600HHF 2015 Transaxle Drive Belt Replacement, Rear Guard: step 2, image 1 of 1
    • Use a 1/2" socket or wrench to remove the two 26 mm bolts securing the rear guard to the back end of the brush cutter.
  3. Billy Goat Brush Cutter BC2600HHF 2015 Transaxle Drive Belt Replacement: step 3, image 1 of 2 Billy Goat Brush Cutter BC2600HHF 2015 Transaxle Drive Belt Replacement: step 3, image 2 of 2
    • The brush cutter is heavy—get help before attempting to lift it.
    • If you choose to tip the brush cutter onto its side, first drain the oil and gas.
    • Raise and support the back end of the brush cutter—or tip it carefully onto its side—in order to access the bottom cover.
  4. Billy Goat Brush Cutter BC2600HHF 2015 Transaxle Drive Belt Replacement: step 4, image 1 of 3 Billy Goat Brush Cutter BC2600HHF 2015 Transaxle Drive Belt Replacement: step 4, image 2 of 3 Billy Goat Brush Cutter BC2600HHF 2015 Transaxle Drive Belt Replacement: step 4, image 3 of 3
    • Use a 3/8” socket or wrench to remove the four 21 mm bolts securing the rear guard.
    • Remove the guard.
  5. Billy Goat Brush Cutter BC2600HHF 2015 Transaxle Drive Belt Replacement, Transaxle Drive Belt: step 5, image 1 of 3 Billy Goat Brush Cutter BC2600HHF 2015 Transaxle Drive Belt Replacement, Transaxle Drive Belt: step 5, image 2 of 3 Billy Goat Brush Cutter BC2600HHF 2015 Transaxle Drive Belt Replacement, Transaxle Drive Belt: step 5, image 3 of 3
    • Relieve the tension on the transaxle drive belt by pressing on the back end of the tensioning arm. (Alternatively, use a pry bar on the front end of the tensioning arm, or remove the tensioning spring.)
    • Slip the transaxle drive belt off the drive pulley.
  6. Billy Goat Brush Cutter BC2600HHF 2015 Transaxle Drive Belt Replacement: step 6, image 1 of 3 Billy Goat Brush Cutter BC2600HHF 2015 Transaxle Drive Belt Replacement: step 6, image 2 of 3 Billy Goat Brush Cutter BC2600HHF 2015 Transaxle Drive Belt Replacement: step 6, image 3 of 3
    • Free the belt by sliding it out between the transaxle pulley and the spindle belt.
    • Remove the transaxle drive belt.
4 other people completed this guide.
Jeff Suovanen
439,253 Reputation
259 Guides authored
iFixit Member of iFixit
Staff
118 Members
19,410 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 12
All Time: 2,731
