Bionaire Mini Tower Fan Blade Replacement
  1. Bionaire Mini Tower Fan Blade Replacement, Blades: step 1, image 1 of 2 Bionaire Mini Tower Fan Blade Replacement, Blades: step 1, image 2 of 2
    • There are 6 screws holding the entire fan together, which need to be removed to access the internals of the fan.
  2. Bionaire Mini Tower Fan Blade Replacement: step 2, image 1 of 1
    • Once the screws are all off, the fan can be pulled apart with a little bit of force. However, not too much force is required.
  3. Bionaire Mini Tower Fan Blade Replacement: step 3, image 1 of 3 Bionaire Mini Tower Fan Blade Replacement: step 3, image 2 of 3 Bionaire Mini Tower Fan Blade Replacement: step 3, image 3 of 3
    • Once you have the fan apart, in order to get more maneuverability, the wire attached to the motor needs to be loosened. This can be done by removing the two screws highlighted in red.
  4. Bionaire Mini Tower Fan Blade Replacement: step 4, image 1 of 2 Bionaire Mini Tower Fan Blade Replacement: step 4, image 2 of 2
    • To get more maneuverability, remove the button panel. This can be done by removing the 2 screws on either side of the panel in order to fully remove it.
  5. Bionaire Mini Tower Fan Blade Replacement: step 5, image 1 of 2 Bionaire Mini Tower Fan Blade Replacement: step 5, image 2 of 2
    • Carefully remove the panel by pulling on it. It should fall out easily and separate completely from its housing.
  6. Bionaire Mini Tower Fan Blade Replacement: step 6, image 1 of 2 Bionaire Mini Tower Fan Blade Replacement: step 6, image 2 of 2
    • The bolt that you need to remove is inside of the pre-installed fan blades. With your pliers, grab a hold of the nut and twist to the RIGHT. This will allow you to remove the fan blades.
  7. Bionaire Mini Tower Fan Blade Replacement: step 7, image 1 of 3 Bionaire Mini Tower Fan Blade Replacement: step 7, image 2 of 3 Bionaire Mini Tower Fan Blade Replacement: step 7, image 3 of 3
    • In order to install the new blades, there are two pieces that you have to match up. The blades and pole both have a flat side that you have to match up in order for the blades to stay on.
    • Make sure when you install the blades, it blows air when it rotates in a counterclockwise fashion.
  8. Bionaire Mini Tower Fan Blade Replacement: step 8, image 1 of 1
    • Tighten the bolt to the left and you have successfully installed your new fan blades.
3 other people completed this guide.
Kyle Taggard
218 Reputation
1 Guide authored
Cal Poly, Team 14-4, Green Fall 2015 Member of Cal Poly, Team 14-4, Green Fall 2015
CPSU-GREEN-F15S14G4
5 Members
16 Guides authored
One Comment
Thank you the instructions were spot on
Jason Mendez - Reply
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 40
All Time: 3,739
