Bissell CrossWave Cordless Max 2554A Handle Replacement
  1. Bissell CrossWave Cordless Max 2554A Handle Replacement, Handle: step 1, image 1 of 1
    • Start by facing the vacuum away from you so that you are looking at the back side of the clean water tank.
  2. Bissell CrossWave Cordless Max 2554A Handle Replacement: step 2, image 1 of 3 Bissell CrossWave Cordless Max 2554A Handle Replacement: step 2, image 2 of 3 Bissell CrossWave Cordless Max 2554A Handle Replacement: step 2, image 3 of 3
    • The handle release mechanism is a small hole directly above the clean water tank and below the handle.
    • Using the pointed end of a spudger, press the mechanism to release the handle.
    • You might need to shimmy it a bit, as pressing too hard may prevent the handle from releasing.
  3. Bissell CrossWave Cordless Max 2554A Handle Replacement: step 3, image 1 of 2 Bissell CrossWave Cordless Max 2554A Handle Replacement: step 3, image 2 of 2
    • Remove the handle from the vacuum.
To reassemble your device, reinsert the handle back into the main body of the vacuum, listening for an audible click.
Craig Bowlin
898 Reputation
7 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 28
All Time: 196
