Bissell PowerForce Compact Belt Replacement
  1. Bissell PowerForce Compact Belt Replacement, Belt: step 1, image 1 of 3 Bissell PowerForce Compact Belt Replacement, Belt: step 1, image 2 of 3 Bissell PowerForce Compact Belt Replacement, Belt: step 1, image 3 of 3
    • Remove the 5 screws from the brush plate with the phillips screwdriver.
  2. Bissell PowerForce Compact Belt Replacement: step 2, image 1 of 2 Bissell PowerForce Compact Belt Replacement: step 2, image 2 of 2
    • Lift off the brush plate by grabbing both ends of the plate and lifting the plate up.
  3. Bissell PowerForce Compact Belt Replacement: step 3, image 1 of 3 Bissell PowerForce Compact Belt Replacement: step 3, image 2 of 3 Bissell PowerForce Compact Belt Replacement: step 3, image 3 of 3
    • Grab the rotating brush at both ends.
    • Lift the rotating brush straight out of the vacuum.
    • Remove the belt from the motor pulley.
  4. Bissell PowerForce Compact Belt Replacement: step 4, image 1 of 2 Bissell PowerForce Compact Belt Replacement: step 4, image 2 of 2
    • Clear the bottom of the vacuum from any debris that may be blocking air flow.
    • Clean the rotating brush from any wrapped string or hair. You can use scissors if needed.
  5. Bissell PowerForce Compact Belt Replacement: step 5, image 1 of 3 Bissell PowerForce Compact Belt Replacement: step 5, image 2 of 3 Bissell PowerForce Compact Belt Replacement: step 5, image 3 of 3
    • Check the new belt for any damage.
    • Place the belt on the rotating brush and then the motor pulley.
  6. Bissell PowerForce Compact Belt Replacement: step 6, image 1 of 3 Bissell PowerForce Compact Belt Replacement: step 6, image 2 of 3 Bissell PowerForce Compact Belt Replacement: step 6, image 3 of 3
    • Pull the rotating brush with the belt hooked.
    • Place the ends of the rotating brush into the slots.
    • Rotate the brush a few times to center the belt.
4 other people completed this guide.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 27
All Time: 6,000
