Bissell PowerLifter Brush Belt Replacement
  1. Bissell PowerLifter  Brush Belt Replacement, Brush Belt: step 1, image 1 of 3 Bissell PowerLifter  Brush Belt Replacement, Brush Belt: step 1, image 2 of 3 Bissell PowerLifter  Brush Belt Replacement, Brush Belt: step 1, image 3 of 3
    • Here is the Bissell vacuum cleaner. The front brushes did no longer turn.
    • Unplug the vacuum and turn it over so the bottom of the vacuum can be accessed
    • There are a total of 7 Phillips head screws that need to be removed.
    • One of these screws is behind the height adjustment plate. It must be removed to gain access.
  2. Bissell PowerLifter  Brush Belt Replacement: step 2, image 1 of 3 Bissell PowerLifter  Brush Belt Replacement: step 2, image 2 of 3 Bissell PowerLifter  Brush Belt Replacement: step 2, image 3 of 3
    • Use a flat tip screwdriver to push the tab from the height adjustment plate inwards to the plate to free it from the vacuum cleaner. Procedure is typical for both sides.
    • Remove the height adjustment plate.
    • All Phillips head screws can now be removed.
  3. Bissell PowerLifter  Brush Belt Replacement: step 3, image 1 of 3 Bissell PowerLifter  Brush Belt Replacement: step 3, image 2 of 3 Bissell PowerLifter  Brush Belt Replacement: step 3, image 3 of 3
    • Turn the vacuum around and move the top cover straight up
    • Here is the brush assembly with the belt on the right. This belt was definitely broken.
    • Remove the brush by pulling it straight out.
  4. Bissell PowerLifter  Brush Belt Replacement: step 4, image 1 of 1
    • next place the new belt on the motor drive first, then the brush.
oldturkey03
844,470 Reputation
123 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 9
All Time: 4,981
