Bissell Powerglide Cordless Debris Canister Funnel Replacement
  1. Bissell Powerglide Cordless Debris Canister Funnel Replacement, Filter: step 1, image 1 of 3 Bissell Powerglide Cordless Debris Canister Funnel Replacement, Filter: step 1, image 2 of 3 Bissell Powerglide Cordless Debris Canister Funnel Replacement, Filter: step 1, image 3 of 3
    • Remove the gray motor unit by twisting it so that the black triangle moves from the "locked" to the "unlocked" position.
  2. Bissell Powerglide Cordless Debris Canister Funnel Replacement: step 2, image 1 of 1
    • Remove the filter from the dirt canister.
  3. Bissell Powerglide Cordless Debris Canister Funnel Replacement, Debris Canister Funnel: step 3, image 1 of 1
    • Separate the cyclone assembly from the dirt tank by twisting the pieces counterclockwise.
  4. Bissell Powerglide Cordless Debris Canister Funnel Replacement: step 4, image 1 of 1
    • Use a Phillips head screwdriver to remove the three screws from the bottom of the cyclone assembly.
    • Remove the bottom of the assembly.
  5. Bissell Powerglide Cordless Debris Canister Funnel Replacement: step 5, image 1 of 2 Bissell Powerglide Cordless Debris Canister Funnel Replacement: step 5, image 2 of 2
    • Twist the clear plastic capsule with the fins counterclockwise to remove it.
  6. Bissell Powerglide Cordless Debris Canister Funnel Replacement: step 6, image 1 of 1
    • Twist the blue parts counterclockwise with a good amount of force to remove them.
Joseph Adam Johnson
511 Reputation
5 Guides authored
Cal Poly, Team S21-G2, Banghart Winter 2018 Member of Cal Poly, Team S21-G2, Banghart Winter 2018
CPSU-BANGHART-W18S21G2
5 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 8
All Time: 216
