Bissell Powerglide Cordless Release Button Replacement
  1. Bissell Powerglide Cordless Release Button Replacement, Release Button: step 1, image 1 of 2 Bissell Powerglide Cordless Release Button Replacement, Release Button: step 1, image 2 of 2
    • Press the release button while pulling up on the head of the vacuum to remove the head.
  2. Bissell Powerglide Cordless Release Button Replacement: step 2, image 1 of 1
    • Using a Phillips head screwdriver, unscrew the four screws holding the panel to the shaft of the vacuum.
  3. Bissell Powerglide Cordless Release Button Replacement: step 3, image 1 of 2 Bissell Powerglide Cordless Release Button Replacement: step 3, image 2 of 2
    • Pry the panel up using a spudger and pull up firmly just enough to see the clips of wire on the sides.
  4. Bissell Powerglide Cordless Release Button Replacement: step 4, image 1 of 1
    • Remove the wire clips on both sides of the shaft.
  5. Bissell Powerglide Cordless Release Button Replacement: step 5, image 1 of 1
    • Pull the top piece out of the shaft.
  6. Bissell Powerglide Cordless Release Button Replacement: step 6, image 1 of 3 Bissell Powerglide Cordless Release Button Replacement: step 6, image 2 of 3 Bissell Powerglide Cordless Release Button Replacement: step 6, image 3 of 3
    • Pinch the two pairs of plastic catches (circled in the picture) to release the button.
Khanh Fleshman
133 Reputation
1 Guide authored
CPSU-BANGHART-W18S21G2 Member of CPSU-BANGHART-W18S21G2
Community
1 Member
1 Guide authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 5
All Time: 170
