Bissell SmartClean 1605 Front Cover Replacement
  1. Bissell SmartClean 1605 Front Cover Replacement, Front Cover: step 1, image 1 of 1
    • Power off your device
  2. Bissell SmartClean 1605 Front Cover Replacement: step 2, image 1 of 1
    • Flip your device and unscrew the marked screws using a phillips screwdriver.
  3. Bissell SmartClean 1605 Front Cover Replacement: step 3, image 1 of 3 Bissell SmartClean 1605 Front Cover Replacement: step 3, image 2 of 3 Bissell SmartClean 1605 Front Cover Replacement: step 3, image 3 of 3
    • Gently pry off the top half of the front cover
    • Remove the wires from the socket.
    • Don't pull the wires too hard, they can become disconnected from the plastic plug.
  4. Bissell SmartClean 1605 Front Cover Replacement: step 4, image 1 of 3 Bissell SmartClean 1605 Front Cover Replacement: step 4, image 2 of 3 Bissell SmartClean 1605 Front Cover Replacement: step 4, image 3 of 3
    • Once the top cover is removed, pry off the bottom casing.
Michael Derrenbacher
104 Reputation
1 Guide authored
Cal Poly, Team S7-G4, Banghart Fall 2017 Member of Cal Poly, Team S7-G4, Banghart Fall 2017
CPSU-BANGHART-F17S7G4
5 Members
5 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 290
