Bissell SmartClean 1605 Roller Brush Replacement
  1. Bissell SmartClean 1605 Roller Brush Replacement, Roller Brush: step 1, image 1 of 1
    • Make sure your device is powered off.
  2. Bissell SmartClean 1605 Roller Brush Replacement: step 2, image 1 of 1
    • Gently flip device over.
  3. Bissell SmartClean 1605 Roller Brush Replacement: step 3, image 1 of 3 Bissell SmartClean 1605 Roller Brush Replacement: step 3, image 2 of 3 Bissell SmartClean 1605 Roller Brush Replacement: step 3, image 3 of 3
    • Remove plastic plate cover to reveal brush roller.
  4. Bissell SmartClean 1605 Roller Brush Replacement: step 4, image 1 of 2 Bissell SmartClean 1605 Roller Brush Replacement: step 4, image 2 of 2
    • Remove brush roller from its slots on either side.
    • Apply pressure to one side and pull the roller out of its opposite slot.
    • It's like taking out a spring loaded toilet paper holder.
Austin Maranville
117 Reputation
1 Guide authored
Cal Poly, Team S7-G4, Banghart Fall 2017 Member of Cal Poly, Team S7-G4, Banghart Fall 2017
CPSU-BANGHART-F17S7G4
5 Members
5 Guides authored
13 Comments
What if mine don't feel spring loaded and the brushe seems like it was just wants to fall out
Brian - Reply
I'm having the same issue. The spring is not reloading to the brush just falls out
Rachel -
Same issue with mine. Took it apart and found that the side with spring loaded holder was broken.
Ryan Beaudre - Reply
I am having the same issue it’s like a part is missing for the pin side not the square sides to hold the brush roll in place.
Geoffrey Fraser - Reply
I have the same issue…it seems that the spring part was lost.have anyone of you find a replacement parts?
Mazinger Z - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 11
All Time: 1,058
