Bissell SpotBot Pet Control Panel Replacement
  1. Bissell SpotBot Pet Control Panel Replacement, Control Panel: step 1, image 1 of 1
    • Start here.
  2. Bissell SpotBot Pet Control Panel Replacement: step 2, image 1 of 1
    • Remove the container on the right side of the vacuum.
  3. Bissell SpotBot Pet Control Panel Replacement: step 3, image 1 of 2 Bissell SpotBot Pet Control Panel Replacement: step 3, image 2 of 2
    • Lift the tap on top of the vacuum, and then remove the container on the left side of the vacuum.
  4. Bissell SpotBot Pet Control Panel Replacement: step 4, image 1 of 1
    • Remove the left container of the vacuum.
  5. Bissell SpotBot Pet Control Panel Replacement: step 5, image 1 of 1
    • Remove the four screws on the top of the device.
  6. Bissell SpotBot Pet Control Panel Replacement: step 6, image 1 of 1
    • Lift the top of the device off once the screws are removed.
  7. Bissell SpotBot Pet Control Panel Replacement: step 7, image 1 of 1
    • Unplug the ribbon cable from the motherboard.
  8. Bissell SpotBot Pet Control Panel Replacement: step 8, image 1 of 1
    • Separate the top piece and flip it upside down.
  9. Bissell SpotBot Pet Control Panel Replacement: step 9, image 1 of 2 Bissell SpotBot Pet Control Panel Replacement: step 9, image 2 of 2
    • Remove the screws holding the motherboard in place.
  10. Bissell SpotBot Pet Control Panel Replacement: step 10, image 1 of 2 Bissell SpotBot Pet Control Panel Replacement: step 10, image 2 of 2
    • Remove the motherboard from the top piece. Repair or replace the motherboard if it is faulty.
4 other people completed this guide.
Anthony Bonvino
437 Reputation
2 Guides authored
Cal Poly, Team S7-G3, Banghart Fall 2017 Member of Cal Poly, Team S7-G3, Banghart Fall 2017
CPSU-BANGHART-F17S7G3
4 Members
4 Guides authored
1 Guide Comment
Where can I buy the part?
Sue Loberger - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 13
All Time: 722
