Bissell SpotBot Pet Hose Assembly Replacement
  1. Bissell SpotBot Pet Hose Assembly Replacement, Cleaning solution tank: step 1, image 1 of 1
    • Remove cleaning solution tank.
  2. Bissell SpotBot Pet Hose Assembly Replacement, Waste storage tank: step 2, image 1 of 1
    • Remove waste storage tank.
  3. Bissell SpotBot Pet Hose Assembly Replacement, Top cover: step 3, image 1 of 1
    • Remove (4) Phillips head screws.
  4. Bissell SpotBot Pet Hose Assembly Replacement, Top cover removal: step 4, image 1 of 1
    • Remove top cover. Unplug ribbon cable from control board and set top aside.
  5. Bissell SpotBot Pet Hose Assembly Replacement: step 5, image 1 of 2 Bissell SpotBot Pet Hose Assembly Replacement: step 5, image 2 of 2
    • Remove the two screws and gently move white box with wires out of the way.
  6. Bissell SpotBot Pet Hose Assembly Replacement, Solution tubing removal: step 6, image 1 of 1
    • Locate end of clear rubber tubing and remove clamp with pliers. It is nearly impossible to get the hose end off of the hose barb, so I just cut the hose close to the barb, then gently scored the tubing left on the barb to get it off.
    • Remove hose assembly by gently twisting up on hose. This end is just snug-fit with 2 O-Rings.
    • Install new hose assembly by adding a little silicone-based grease on the 2 o-rings and inserting the hose end into the hole by the waste tank inlet port. Then attatch the clear tubing on the barb, then replace the hose clamp.
5 other people completed this guide.
Tim Lough
301 Reputation
1 Guide authored
8 Comments
Thanks Tim! You made that very easy and straight forward. I was done in 10 minutes.
David Root - Reply
Not a problem, glad it worked for you! Mine is still going strong after 2 years.
Tim Lough -
Worked like a charm. You had very good pictures and easy to understand explanation
Bruce Bradford - Reply
This is great thanks!  I got as far removing the clamps and was afraid to move forward, my replacement hose did not come with new clamps and I am worried I will break them.  This is my first time working with clamps.  I searched the internet and found your site.  This is wonderful, thank you very much.
brigadoonsetters - Reply
Breathed new life into our SpotBot with these instructions, thank you!!
Anthony Clark - Reply
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 97
All Time: 7,095
