Bissell SpotClean ProHeat 5207U Float Stack Replacement
  1. Bissell SpotClean ProHeat 5207U Float Stack Replacement, Float Stack: step 1, image 1 of 1
    • Ensure Bissell SpotClean ProHeat is unplugged.
    • Position your hand vacuum so that you can see the text at the bottom saying "SpotClean ProHeat."
  2. Bissell SpotClean ProHeat 5207U Float Stack Replacement: step 2, image 1 of 2 Bissell SpotClean ProHeat 5207U Float Stack Replacement: step 2, image 2 of 2
    • Remove the dirty water tank. It is the tank on the right.
    • The tank reads "dirty" on the bottom on the inner edge.
  3. Bissell SpotClean ProHeat 5207U Float Stack Replacement: step 3, image 1 of 3 Bissell SpotClean ProHeat 5207U Float Stack Replacement: step 3, image 2 of 3 Bissell SpotClean ProHeat 5207U Float Stack Replacement: step 3, image 3 of 3
    • Rotate the bottom of the float stack counterclockwise until the float stack comes lose.
    • Remove the float stack from the tank.
  4. Bissell SpotClean ProHeat 5207U Float Stack Replacement: step 4, image 1 of 3 Bissell SpotClean ProHeat 5207U Float Stack Replacement: step 4, image 2 of 3 Bissell SpotClean ProHeat 5207U Float Stack Replacement: step 4, image 3 of 3
    • Grab the float on the float Stack assembly
    • Slide the float down towards the base.
    • Remove float and clean any debris found.
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 29
All Time: 715
