Bissell SpotClean ProHeat 5207U Hose Replacement
  1. Bissell SpotClean ProHeat 5207U Hose Replacement, Water Hose: step 1, image 1 of 2 Bissell SpotClean ProHeat 5207U Hose Replacement, Water Hose: step 1, image 2 of 2
    • Ensure Bissell SpotClean ProHeat is unplugged
    • Position your hand vacuum so that you can see the text at the bottom saying "SpotClean ProHeat."
    • Remove the dirty water tank and the clean water tank that are located on either side.
  2. Bissell SpotClean ProHeat 5207U Hose Replacement: step 2, image 1 of 3 Bissell SpotClean ProHeat 5207U Hose Replacement: step 2, image 2 of 3 Bissell SpotClean ProHeat 5207U Hose Replacement: step 2, image 3 of 3
    • Turn the device so that the bottom is facing up.
    • Remove the marked 19.7 mm screws using the Phillips #00 screwdriver to remove the plastic covering.
    • Remove the plastic top located where the dirty water tank was previously situated.
    • Using the Phillips #00 screwdriver, unscrew the three screws located under the plastic cover that was previously removed.
  3. Bissell SpotClean ProHeat 5207U Hose Replacement: step 3, image 1 of 2 Bissell SpotClean ProHeat 5207U Hose Replacement: step 3, image 2 of 2
    • Remove the plastic lip that was previously held by the screws.
    • Remove the 17.2 mm screws using the Phillips #00 Screwdriver to gain access to the water pump.
  4. Bissell SpotClean ProHeat 5207U Hose Replacement: step 4, image 1 of 2 Bissell SpotClean ProHeat 5207U Hose Replacement: step 4, image 2 of 2
    Tool used on this step:
    Buy
    • Use the tweezers to to squeeze together the prongs of the hose clamp.
    • With the clamp squeezed, pull the hose from the pump.
    • We found it easier to pull the clamp up the hose then pull the hose from the pump.
  5. Bissell SpotClean ProHeat 5207U Hose Replacement: step 5, image 1 of 1
    • Pull the hose from the opposite end of the pump until it is fully removed.
    • Replace the previous non-working hose with a new working hose.
3 other people completed this guide.
0 Comments
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 89
All Time: 584
