Black and Decker BDEDMT Circuit Board Replacement
  1. Black and Decker BDEDMT Circuit Board Replacement, Detach Matrix Attachment: step 1, image 1 of 2 Black and Decker BDEDMT Circuit Board Replacement, Detach Matrix Attachment: step 1, image 2 of 2
    • Remember to disconnect the device from all external power sources.
    • To detach the matrix attachment piece, press down on the attachment release button located at the top of the device.
    • Leaving your finger pressed down on the button, simply pull on the attachment to release it.
  2. Black and Decker BDEDMT Circuit Board Replacement, Remove Mounting Hardware: step 2, image 1 of 3 Black and Decker BDEDMT Circuit Board Replacement, Remove Mounting Hardware: step 2, image 2 of 3 Black and Decker BDEDMT Circuit Board Replacement, Remove Mounting Hardware: step 2, image 3 of 3
    • Using a JIS 1 screwdriver, unscrew seven 19mm outer screws located on the armature.
    • Using the same screwdriver, unscrew the 12mm outer screw located on the armature.
  3. Black and Decker BDEDMT Circuit Board Replacement, Circuit Board: step 3, image 1 of 2 Black and Decker BDEDMT Circuit Board Replacement, Circuit Board: step 3, image 2 of 2
    Tool used on this step:
    Buy
    • There will be a white cord that runs from the power cord base to the circuit board located slightly above.
    • Use the tweezers to detach the entire white cord and blue connection piece as a whole from the circuit board.
  4. Black and Decker BDEDMT Circuit Board Replacement: step 4, image 1 of 3 Black and Decker BDEDMT Circuit Board Replacement: step 4, image 2 of 3 Black and Decker BDEDMT Circuit Board Replacement: step 4, image 3 of 3
    • There will be one black wire, a thin white wire and a thin red wire connecting to the trigger module from the circuit board. Using your needle nose tweezers insert one of the ends into the release slot below the white wire.
    • Make sure to aim the tweezers toward the wire.
    • Lift the end of the tweezers to release the wire.
    • The Circuit board is now free.
    • Do not force the removal of the wire.
    • Remember to reinsert the wires to their corresponding slots when reassembling.
Edgardo Gutierrez Jr
329 Reputation
2 Guides authored
UW Tacoma, Team 1-2, Rose Winter 2016 Member of UW Tacoma, Team 1-2, Rose Winter 2016
UWT-ROSE-W16S1G2
4 Members
11 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 48
All Time: 789
