Black and Decker BDEDMT Directional Switch Replacement
  1. Black and Decker BDEDMT Directional Switch Replacement, Detach Matrix Attachment: step 1, image 1 of 2 Black and Decker BDEDMT Directional Switch Replacement, Detach Matrix Attachment: step 1, image 2 of 2
    • Remember to disconnect the device from all external power sources.
    • To detach the matrix attachment piece, press down on the attachment release button located at the top of the device.
    • Leaving your finger pressed down on the button, simply pull on the attachment to release it.
  2. Black and Decker BDEDMT Directional Switch Replacement, Remove Mounting Hardware: step 2, image 1 of 3 Black and Decker BDEDMT Directional Switch Replacement, Remove Mounting Hardware: step 2, image 2 of 3 Black and Decker BDEDMT Directional Switch Replacement, Remove Mounting Hardware: step 2, image 3 of 3
    • Using a JIS 1 screwdriver, unscrew seven 19mm outer screws located on the armature.
    • Using the same screwdriver, unscrew the 12mm outer screw located on the armature.
  3. Black and Decker BDEDMT Directional Switch Replacement, Directional Switch: step 3, image 1 of 2 Black and Decker BDEDMT Directional Switch Replacement, Directional Switch: step 3, image 2 of 2
    • Gently pull up on the trigger module.
    • Be sure to not loosen or disturb any wiring.
  4. Black and Decker BDEDMT Directional Switch Replacement: step 4, image 1 of 2 Black and Decker BDEDMT Directional Switch Replacement: step 4, image 2 of 2
    Tool used on this step:
    Buy
    • With the trigger module out of the way you will then remove the metal piece that is located behind the directional switch and has the spring attached to it.
    • Do this by simply pulling up on the metal with your fingers or your tweezers.
    • Make sure to not loosen or remove the black trigger stopper.
  5. Black and Decker BDEDMT Directional Switch Replacement: step 5, image 1 of 2 Black and Decker BDEDMT Directional Switch Replacement: step 5, image 2 of 2
    • The black directional switch can now be freely removed.
Tyler Yurina
419 Reputation
2 Guides authored
UW Tacoma, Team 1-2, Rose Winter 2016 Member of UW Tacoma, Team 1-2, Rose Winter 2016
UWT-ROSE-W16S1G2
4 Members
11 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 20
All Time: 400
