Black and Decker BDEDMT Motor Replacement
  1. Black and Decker BDEDMT Motor Replacement, Detach Matrix Attachment: step 1, image 1 of 2 Black and Decker BDEDMT Motor Replacement, Detach Matrix Attachment: step 1, image 2 of 2
    • Remember to disconnect the device from all external power sources.
    • To detach the matrix attachment piece, press down on the attachment release button located at the top of the device.
    • Leaving your finger pressed down on the button, simply pull on the attachment to release it.
  2. Black and Decker BDEDMT Motor Replacement, Remove Mounting Hardware: step 2, image 1 of 3 Black and Decker BDEDMT Motor Replacement, Remove Mounting Hardware: step 2, image 2 of 3 Black and Decker BDEDMT Motor Replacement, Remove Mounting Hardware: step 2, image 3 of 3
    • Using a JIS 1 screwdriver, unscrew seven 19mm outer screws located on the armature.
    • Using the same screwdriver, unscrew the 12mm outer screw located on the armature.
  3. Black and Decker BDEDMT Motor Replacement, Motor: step 3, image 1 of 1
    • Gently pull up the motor and other components at the top of the device except the handle.
    • Watch out for the wires. They are connected to two compressed magnets in the black framework.
  4. Black and Decker BDEDMT Motor Replacement: step 4, image 1 of 2 Black and Decker BDEDMT Motor Replacement: step 4, image 2 of 2
    • Slide off the the black framework on the barring side.
    • You may have to compress the magnets in order to slide the framework off of the barring.
  5. Black and Decker BDEDMT Motor Replacement: step 5, image 1 of 2 Black and Decker BDEDMT Motor Replacement: step 5, image 2 of 2
    • Remove the release button attached at the front of the motor.
    • It may have already come off during Step 3.
  6. Black and Decker BDEDMT Motor Replacement: step 6, image 1 of 2 Black and Decker BDEDMT Motor Replacement: step 6, image 2 of 2
    • Work the silver magnetic ring off of the motor through the barring end.
    • The motor is now free.
Tyler Yurina
419 Reputation
2 Guides authored
UW Tacoma, Team 1-2, Rose Winter 2016 Member of UW Tacoma, Team 1-2, Rose Winter 2016
UWT-ROSE-W16S1G2
4 Members
11 Guides authored
3 Comments
Hi,
Please can you tell me where to find the motor replacement part for this tool?
Thank you
Renato - Reply
I have this tool and the attachments and I absolutely love it…but I'm pretty sure the gears are stripped…do you know anything about replacing those?
cwilson0713@gmail.com - Reply
Past 24 Hours: 0
Past 7 Days: 14
Past 30 Days: 60
All Time: 2,752
