Black and Decker BDH9600CHV Power Switch Replacement
  1. Black and Decker BDH9600CHV Power Switch Replacement, Power Switch: step 1, image 1 of 3 Black and Decker BDH9600CHV Power Switch Replacement, Power Switch: step 1, image 2 of 3 Black and Decker BDH9600CHV Power Switch Replacement, Power Switch: step 1, image 3 of 3
    • To remove the filter and housing, press the green button labeled "Filter".
  2. Black and Decker BDH9600CHV Power Switch Replacement: step 2, image 1 of 1
    • Unscrew and remove all 5 screws using the Phillips 0 screw bit. Each screw is 17.5 mm long.
  3. Black and Decker BDH9600CHV Power Switch Replacement: step 3, image 1 of 2 Black and Decker BDH9600CHV Power Switch Replacement: step 3, image 2 of 2
    • Pull the housing apart.
    • When you pull the housing apart, pieces may fall out. Be sure to track of the parts and where they go.
    • Remove the switch by pulling it out.
  4. Black and Decker BDH9600CHV Power Switch Replacement: step 4, image 1 of 2 Black and Decker BDH9600CHV Power Switch Replacement: step 4, image 2 of 2
    • Replace the new switch by sliding the replacement switch onto the top of the switch mechanism located on the motor.
Ivette Muzquiz
349 Reputation
3 Guides authored
IUPUI, Team S1-G4, Harley Fall 2017 Member of IUPUI, Team S1-G4, Harley Fall 2017
IUPUI-HARLEY-F17S1G4
3 Members
3 Guides authored
One Comment
My switch with up & down button box like
Fernando Palacios - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 18
All Time: 1,151
