Black and Decker BV2500 Type 4 Clamshell (Black Outer Casing) Replacement
  1. Black and Decker BV2500 Type 4 Clamshell (Black Outer Casing) Replacement, Clamshell (Black Outer Casing): step 1, image 1 of 1
    • Using a Phillips #2 screwdriver, remove the six 20 mm screws in the black plastic casing (clamshell).
  2. Black and Decker BV2500 Type 4 Clamshell (Black Outer Casing) Replacement: step 2, image 1 of 2 Black and Decker BV2500 Type 4 Clamshell (Black Outer Casing) Replacement: step 2, image 2 of 2
    • Using your hands, remove the blower tube and clamshell.
    • To remove the clamshell, pull apart starting from the bottom until it is pulled out from the notches. Then slide it out away from the device.
Angelica Chow
409 Reputation
3 Guides authored
Cal Poly, Team 9-29, Maness Winter 2014 Member of Cal Poly, Team 9-29, Maness Winter 2014
CPSU-MANESS-W14S9G29
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 745
