Black and Decker BV2500 Type 4 Powerhead Assembly Replacement
  1. Black and Decker BV2500 Type 4 Powerhead Assembly Replacement, Clamshell (Black Outer Casing): step 1, image 1 of 1
    • Using a Phillips #2 screwdriver, remove the six 20 mm screws in the black plastic casing (clamshell).
  2. Black and Decker BV2500 Type 4 Powerhead Assembly Replacement: step 2, image 1 of 2 Black and Decker BV2500 Type 4 Powerhead Assembly Replacement: step 2, image 2 of 2
    • Using your hands, remove the blower tube and clamshell.
    • To remove the clamshell, pull apart starting from the bottom until it is pulled out from the notches. Then slide it out away from the device.
  3. Black and Decker BV2500 Type 4 Powerhead Assembly Replacement, Powerhead Assembly: step 3, image 1 of 1
    • The powerhead assembly is the entire orange part of the device.
    • Replace it with a new powerhead assembly.
Angelica Chow
409 Reputation
3 Guides authored
Cal Poly, Team 9-29, Maness Winter 2014 Member of Cal Poly, Team 9-29, Maness Winter 2014
CPSU-MANESS-W14S9G29
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 20
All Time: 1,228
