Black and Decker BV2500 Type 4 Switch Replacement
  1. Black and Decker BV2500 Type 4 Switch Replacement, Clamshell (Black Outer Casing): step 1, image 1 of 1
    • Using a Phillips #2 screwdriver, remove the six 20 mm screws in the black plastic casing (clamshell).
  2. Black and Decker BV2500 Type 4 Switch Replacement: step 2, image 1 of 2 Black and Decker BV2500 Type 4 Switch Replacement: step 2, image 2 of 2
    • Using your hands, remove the blower tube and clamshell.
    • To remove the clamshell, pull apart starting from the bottom until it is pulled out from the notches. Then slide it out away from the device.
  3. Black and Decker BV2500 Type 4 Switch Replacement, Switch: step 3, image 1 of 2 Black and Decker BV2500 Type 4 Switch Replacement, Switch: step 3, image 2 of 2
    • Locate and unscrew the ten 20 mm Phillips #2 screws in the orange casing with a Phillips #2 screwdriver.
    • Using your hands, lift off side of the orange casing with the screws facing you.
  4. Black and Decker BV2500 Type 4 Switch Replacement: step 4, image 1 of 3 Black and Decker BV2500 Type 4 Switch Replacement: step 4, image 2 of 3 Black and Decker BV2500 Type 4 Switch Replacement: step 4, image 3 of 3
    • Locate the switch on the handle of the blower.
    • Carefully remove the four wires that are attached to the switch.
    • Use your hand to push in the sides of the switch and slide out the wires.
  5. Black and Decker BV2500 Type 4 Switch Replacement: step 5, image 1 of 1
    • Note for reassembly: Be sure to put this back the way it was found.
Jon Gori
137 Reputation
1 Guide authored
Cal Poly, Team 9-29, Maness Winter 2014 Member of Cal Poly, Team 9-29, Maness Winter 2014
CPSU-MANESS-W14S9G29
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 22
All Time: 3,411
