Black and Decker DustBuster 15.6V Suction Rubber Seal Replacement
  1. Black and Decker DustBuster 15.6V Suction Rubber Seal Replacement, Suction Rubber Seal: step 1, image 1 of 1
    • Press to blue unlock buttons at the base of the nozzle in word and pull forward .
  2. Black and Decker DustBuster 15.6V Suction Rubber Seal Replacement: step 2, image 1 of 1
    • Locate rubber suction seal.
  3. Black and Decker DustBuster 15.6V Suction Rubber Seal Replacement: step 3, image 1 of 1
    • Insert a metal spudger in between white plastic and rubber seal and gently drag spudger around see you lifting gently much like opening a can.
  4. Black and Decker DustBuster 15.6V Suction Rubber Seal Replacement: step 4, image 1 of 1
    • Align slits on the bottom of new suction seal then press into those slits.
    • The seal should not come above white plastic.
    • If the nozzle does not connect to vacuum barrel, readjust seal and try to attach nozzle until it snaps into place.
Roberto Perez
101 Reputation
1 Guide authored
One Comment
Where can I buy a new suction seal.
Alison Junk - Reply
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 27
All Time: 2,348
