Black and Decker JE2200B Disassembly
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Black and Decker JE2200B Disassembly, Unlocking Latches: step 1, image 1 of 2 Black and Decker JE2200B Disassembly, Unlocking Latches: step 1, image 2 of 2
    • To undo the locking latches: Pull outwards at the bottom of each latch to detach them from the groove on the cover .
  2. Black and Decker JE2200B Disassembly, Removing the Cover: step 2, image 1 of 2 Black and Decker JE2200B Disassembly, Removing the Cover: step 2, image 2 of 2
    • To remove the cover: Take out the feeder, hold the chute firmly and pull up the cover.
  3. Black and Decker JE2200B Disassembly, Remove Pulp Separator: step 3, image 1 of 1
    • To remove the pulp container: Hold the juice spout with one hand and the back edge of the pulp separator with the other hand. Pull it up while making sure that the cutter/strainer is kept in place
  4. Black and Decker JE2200B Disassembly, Remove Cutter/Strainer: step 4, image 1 of 3 Black and Decker JE2200B Disassembly, Remove Cutter/Strainer: step 4, image 2 of 3 Black and Decker JE2200B Disassembly, Remove Cutter/Strainer: step 4, image 3 of 3
    • To remove the cutter/strainer: Hold the juice spout with one hand and clutch the edge of the cutter/strainer with the other hand; pull it out slowly.
    • ' The teeth on the cutter/strainer are very sharp. '
  5. Black and Decker JE2200B Disassembly, Remove Pulp Container: step 5, image 1 of 1
    • To remove the pulp separator: Hold the sides firmly and pull the container out.
To reassemble your device, follow this guide in reverse order.
Bhavika Shah
331 Reputation
2 Guides authored
USF Tampa, Team 5-5, Blackwell Fall 2015 Member of USF Tampa, Team 5-5, Blackwell Fall 2015
USFT-BLACKWELL-F15S5G5
3 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 9
All Time: 727
