Black and Decker JS660 Blade Holder Replacement
  1. Black and Decker JS660 Blade Holder Replacement, Base: step 1, image 1 of 2 Black and Decker JS660 Blade Holder Replacement, Base: step 1, image 2 of 2
    • Unscrew the eight screws to open up the jigsaw.
  2. Black and Decker JS660 Blade Holder Replacement: step 2, image 1 of 1
    • Use a screwdriver to remove the first screws securing the base to the jigsaw.
    • Remove the second screw.
    • Remove the base of the jigsaw.
  3. Black and Decker JS660 Blade Holder Replacement: step 3, image 1 of 2 Black and Decker JS660 Blade Holder Replacement: step 3, image 2 of 2
    • With the old jigsaw base off, replace it with the new base by following the steps in the reverse order.
    • Assemble the base on a steady surface.
  4. Black and Decker JS660 Blade Holder Replacement, Blade Holder: step 4, image 1 of 2 Black and Decker JS660 Blade Holder Replacement, Blade Holder: step 4, image 2 of 2
    • You will need to take out the entire blade clamp shown.
    • The plastic part is fragile, easy to break
  5. Black and Decker JS660 Blade Holder Replacement: step 5, image 1 of 3 Black and Decker JS660 Blade Holder Replacement: step 5, image 2 of 3 Black and Decker JS660 Blade Holder Replacement: step 5, image 3 of 3
    • Showing the entire blade clamp removed from the device.
    • Apply some oil grease if dry/needed
Andrew Khouri
468 Reputation
4 Guides authored
USF Tampa, Team 6-2, Eyestone Spring 2016 Member of USF Tampa, Team 6-2, Eyestone Spring 2016
USFT-EYESTONE-S16S6G2
4 Members
4 Guides authored
One Comment
What a great website… I could never have known how to replace the blade holder… Or that I could get the correct parts…I got the replacement part. Then removed the old one, and replaced the new one. NO problem at all.. Thanks to Andrew and this website… With out it, would have to pay some one at a big price, and wait to have it fixed, as would have to send it off for the repair.. Or….. Just throw it away…
Thanks every one… I will share this site for sure…
navy1aedon - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 3,389
