Black and Decker LI4000 Battery Replacement
  1. Black and Decker LI4000 Battery Replacement, Outer Casing: step 1, image 1 of 3 Black and Decker LI4000 Battery Replacement, Outer Casing: step 1, image 2 of 3 Black and Decker LI4000 Battery Replacement, Outer Casing: step 1, image 3 of 3
    • Remove the stickers found on the bottom and sides of the LI4000, using a spudger.
  2. Black and Decker LI4000 Battery Replacement: step 2, image 1 of 1
    • Remove all six of the 12-mm long case screws with a Philips #1 Screwdriver. These screws can be found on the side of the LI4000 with the "Warning" sticker.
  3. Black and Decker LI4000 Battery Replacement: step 3, image 1 of 2 Black and Decker LI4000 Battery Replacement: step 3, image 2 of 2
    • Remove the two screws that are 4-mm Hexagonal #2.5. These are very small case screws that can be found underneath the two stickers from Step 1.
  4. Black and Decker LI4000 Battery Replacement: step 4, image 1 of 2 Black and Decker LI4000 Battery Replacement: step 4, image 2 of 2
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The metal spudger is great when you need serious prying power, but the regular black nylon spudger or a plastic opening tool should be used whenever possible.
    • Pry on the seam as shown with a Spudger, in order to get the top casing loose.
    • Pull the two sides apart while making sure the side that you are removing is the one with all of the case screw holes.
    • It is good practice to remove the top connection of the battery as shown in the third image, as this will be the first step to replacing any of the components for this screwdriver.
  5. Black and Decker LI4000 Battery Replacement, Battery: step 5, image 1 of 1
    • Locate the battery. The cardboard covered cylinder is the rechargeable battery.
  6. Black and Decker LI4000 Battery Replacement: step 6, image 1 of 2 Black and Decker LI4000 Battery Replacement: step 6, image 2 of 2
    • Detach the contact by pulling the contact away from the battery.
  7. Black and Decker LI4000 Battery Replacement: step 7, image 1 of 2 Black and Decker LI4000 Battery Replacement: step 7, image 2 of 2
    • Gently lift the end of the battery out of the plastic casing
  8. Black and Decker LI4000 Battery Replacement: step 8, image 1 of 1
    • Locate the other contact on the rear side of the battery.
  9. Black and Decker LI4000 Battery Replacement: step 9, image 1 of 2 Black and Decker LI4000 Battery Replacement: step 9, image 2 of 2
  10. Black and Decker LI4000 Battery Replacement: step 10, image 1 of 1
    • To install a new battery, repeat the steps in reverse order with a new battery.
17 other people completed this guide.
Nicholas Kniola
527 Reputation
1 Guide authored
IUPUI, Team 2-3, Baechle Spring 2016 Member of IUPUI, Team 2-3, Baechle Spring 2016
IUPUI-BAECHLE-S16S2G3
3 Members
8 Guides authored
5 Comments
Anyone know what type of battery this is so I can replace it?
Thanks
Brian
Brian Wong - Reply
If you peel off the paper of the battery, you will find out that it is a 18650 Lithium battery. Mine has US18650VT T11250 label. It seems from SONY.
River Seow - Reply
When looking for a replacement battery, see if you can find one with solder tabs opposite to each other. The internal plastic housing of the battery is made exactly for two tabs opposing each other; I had to cut the plastic here and there to make my battery (with both tabs at the same side) fit.
Xian Lu - Reply
New one is cheaper than a new battery
Wolfie Shay - Reply
new battery costs 10$, its a 18650 or LI4000
GEEnius - Reply
Past 24 Hours: 4
Past 7 Days: 19
Past 30 Days: 113
All Time: 11,159
