Black and Decker One Step Steam Iron Temperature Regulator Replacement
  1. Black and Decker One Step Steam Iron Temperature Regulator Replacement, Temperature Regulator: step 1, image 1 of 2 Black and Decker One Step Steam Iron Temperature Regulator Replacement, Temperature Regulator: step 1, image 2 of 2
    • Use a spudger to pry the three screw covers out of the iron.
    • Using force to remove the caps may be necessary. Do not worry if you hear popping sounds when removing them.
  2. Black and Decker One Step Steam Iron Temperature Regulator Replacement: step 2, image 1 of 1
    • Remove the three screws using a T5 Torx screwdriver.
  3. Black and Decker One Step Steam Iron Temperature Regulator Replacement: step 3, image 1 of 1
    • Pull the back cover off.
  4. Black and Decker One Step Steam Iron Temperature Regulator Replacement: step 4, image 1 of 2 Black and Decker One Step Steam Iron Temperature Regulator Replacement: step 4, image 2 of 2
    • Use a spudger to remove the clear rubber cover from the front of the iron.
  5. Black and Decker One Step Steam Iron Temperature Regulator Replacement: step 5, image 1 of 1
    • Remove the single screw located under the rubber cover using a Phillips #0 screwdriver.
  6. Black and Decker One Step Steam Iron Temperature Regulator Replacement: step 6, image 1 of 1
    • Remove the two screws holding the handle to the base using a Phillips #0 screwdriver.
  7. Black and Decker One Step Steam Iron Temperature Regulator Replacement: step 7, image 1 of 1
    • Remove the screws holding the plate to the base using a Phillips #0 screwdriver.
  8. Black and Decker One Step Steam Iron Temperature Regulator Replacement: step 8, image 1 of 3 Black and Decker One Step Steam Iron Temperature Regulator Replacement: step 8, image 2 of 3 Black and Decker One Step Steam Iron Temperature Regulator Replacement: step 8, image 3 of 3
    • Insert a spudger into the space in front of the pumps.
    • Pull down on the spudger so that the tab is visible.
    • Repeat for the other pump.
  9. Black and Decker One Step Steam Iron Temperature Regulator Replacement: step 9, image 1 of 1
    • Remove the two screws using a Phillips #0 screwdriver.
  10. Black and Decker One Step Steam Iron Temperature Regulator Replacement: step 10, image 1 of 1
    • Push the spray nozzle using the pointed end of a spudger.
  11. Black and Decker One Step Steam Iron Temperature Regulator Replacement: step 11, image 1 of 1
    • Remove the handle from the base.
  12. Black and Decker One Step Steam Iron Temperature Regulator Replacement: step 12, image 1 of 1
    • Remove the two pumps.
  13. Black and Decker One Step Steam Iron Temperature Regulator Replacement: step 13, image 1 of 2 Black and Decker One Step Steam Iron Temperature Regulator Replacement: step 13, image 2 of 2
    • Pry the white plastic cylinder out from its hole using a spudger.
    • The plastic cylinder is held in place by the plastic arm. Some force will be necessary.
  14. Black and Decker One Step Steam Iron Temperature Regulator Replacement: step 14, image 1 of 2 Black and Decker One Step Steam Iron Temperature Regulator Replacement: step 14, image 2 of 2
    • Using two spudger, pry the two plastic pieces holding the lever away from the lever.
    • Lift the lever out.
  15. Black and Decker One Step Steam Iron Temperature Regulator Replacement: step 15, image 1 of 1
    • Pull the lever and its attached pump out of the base.
  16. Black and Decker One Step Steam Iron Temperature Regulator Replacement: step 16, image 1 of 1
  17. Black and Decker One Step Steam Iron Temperature Regulator Replacement: step 17, image 1 of 1
    • Insert a spudger in between the white plastic and the purple plastic.
  18. Black and Decker One Step Steam Iron Temperature Regulator Replacement: step 18, image 1 of 1
    • Rotate the spudger so that it separates the top of the white plastic from the bottom of the purple plastic.
  19. Black and Decker One Step Steam Iron Temperature Regulator Replacement: step 19, image 1 of 1
    • Move the spudger along the gap until you hear a popping noise.
  20. Black and Decker One Step Steam Iron Temperature Regulator Replacement: step 20, image 1 of 1
    • Verify that the tab is detached.
  21. Black and Decker One Step Steam Iron Temperature Regulator Replacement: step 21, image 1 of 2 Black and Decker One Step Steam Iron Temperature Regulator Replacement: step 21, image 2 of 2
    • Separate the white plastic from the bottom purple plastic.
    • Hold the top section (white and purple) steady with one hand.
    • Pull the plate (bottom) section toward the side with the tab shown in Step 20 until the plate is detached.
  22. Black and Decker One Step Steam Iron Temperature Regulator Replacement: step 22, image 1 of 1
    • Use the spudger to gently pop the pump connecter off of the plate.
  23. Black and Decker One Step Steam Iron Temperature Regulator Replacement: step 23, image 1 of 1
    • Remove the three visible screws using a Phillips #0 screwdriver.
  24. Black and Decker One Step Steam Iron Temperature Regulator Replacement: step 24, image 1 of 1
    • Remove the plate holder.
  25. Black and Decker One Step Steam Iron Temperature Regulator Replacement: step 25, image 1 of 1
    • Remove the screw using a Phillips #0 screwdriver.
    • Remove the temperature regulator from the iron.
5 other people completed this guide.
0 Comments
Past 24 Hours: 8
Past 7 Days: 64
Past 30 Days: 242
All Time: 4,990
