Black and Decker PS1800 Actuator Fwd/Rev Replacement
  1. Black and Decker PS1800  Actuator Fwd/Rev Replacement, Open the Outer Drill Case: step 1, image 1 of 2 Black and Decker PS1800  Actuator Fwd/Rev Replacement, Open the Outer Drill Case: step 1, image 2 of 2
    • Lay the drill on its side, assuring that the screw holes are facing upwards.
    • Remove seven 12 mm screws using a Phillips #00 screwdriver.
  2. Black and Decker PS1800  Actuator Fwd/Rev Replacement: step 2, image 1 of 1
    • Separate the outer drill case to expose the components and switch.
  3. Black and Decker PS1800  Actuator Fwd/Rev Replacement, Actuator Fwd/Rev: step 3, image 1 of 3 Black and Decker PS1800  Actuator Fwd/Rev Replacement, Actuator Fwd/Rev: step 3, image 2 of 3 Black and Decker PS1800  Actuator Fwd/Rev Replacement, Actuator Fwd/Rev: step 3, image 3 of 3
    • Start separating the outer shell into two parts.
    • You will find the Fwd/Rev actuator on the right side of the drill, underneath the motor.
  4. Black and Decker PS1800  Actuator Fwd/Rev Replacement: step 4, image 1 of 3 Black and Decker PS1800  Actuator Fwd/Rev Replacement: step 4, image 2 of 3 Black and Decker PS1800  Actuator Fwd/Rev Replacement: step 4, image 3 of 3
    • Carefully remove the actuator from the drill.
    • Replace the new actuator by inserting it the same way you took it out.
2 other people completed this guide.
Hamza Nawaz
247 Reputation
2 Guides authored
IUPUI, Team 2-3, Baechle Fall 2016 Member of IUPUI, Team 2-3, Baechle Fall 2016
IUPUI-BAECHLE-F16S2G3
5 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 14
All Time: 812
