Black and Decker PS1800 Switch Replacement
  1. Black and Decker PS1800  Switch Replacement, Open the Outer Drill Case: step 1, image 1 of 2 Black and Decker PS1800  Switch Replacement, Open the Outer Drill Case: step 1, image 2 of 2
    • Lay the drill on its side, assuring that the screw holes are facing upwards.
    • Remove seven 12 mm screws using a Phillips #00 screwdriver.
  2. Black and Decker PS1800  Switch Replacement: step 2, image 1 of 1
    • Separate the outer drill case to expose the components and switch.
  3. Black and Decker PS1800  Switch Replacement, Switch: step 3, image 1 of 2 Black and Decker PS1800  Switch Replacement, Switch: step 3, image 2 of 2
    • Identify the switch in center of the drill.
    • Remove the screws from the switch.
    • Remove the switch cover.
  4. Black and Decker PS1800  Switch Replacement: step 4, image 1 of 1
    • Locate the switch inside the drill.
    • Remove the switch from the drill.
  5. Black and Decker PS1800  Switch Replacement: step 5, image 1 of 2 Black and Decker PS1800  Switch Replacement: step 5, image 2 of 2
    • Solder off all the joints.
    • Remove the switch assembly.
Hamza Nawaz
247 Reputation
2 Guides authored
IUPUI, Team 2-3, Baechle Fall 2016 Member of IUPUI, Team 2-3, Baechle Fall 2016
IUPUI-BAECHLE-F16S2G3
5 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 16
All Time: 944
