Black and Decker PS1800 Motor Replacement
  1. Black and Decker PS1800 Motor Replacement, Open the Outer Drill Case: step 1, image 1 of 2 Black and Decker PS1800 Motor Replacement, Open the Outer Drill Case: step 1, image 2 of 2
    • Lay the drill on its side, assuring that the screw holes are facing upwards.
    • Remove seven 12 mm screws using a Phillips #00 screwdriver.
  2. Black and Decker PS1800 Motor Replacement: step 2, image 1 of 1
    • Separate the outer drill case to expose the components and switch.
  3. Black and Decker PS1800 Motor Replacement, Disconnect Motor: step 3, image 1 of 3 Black and Decker PS1800 Motor Replacement, Disconnect Motor: step 3, image 2 of 3 Black and Decker PS1800 Motor Replacement, Disconnect Motor: step 3, image 3 of 3
    • Locate the motor at the top left hand corner.
    • Carefully disconnect the red and black wires attached to the motor.
  4. Black and Decker PS1800 Motor Replacement: step 4, image 1 of 1
    • Unscrew the motor from the drill's transmission.
    • Detach the transmission carefully, ensuring that the gears remain intact.
  5. Black and Decker PS1800 Motor Replacement: step 5, image 1 of 2 Black and Decker PS1800 Motor Replacement: step 5, image 2 of 2
    • Remove the motor from the transmission assembly, as pictured.
Christian Aldrich
253 Reputation
2 Guides authored
IUPUI, Team 2-3, Baechle Fall 2016 Member of IUPUI, Team 2-3, Baechle Fall 2016
IUPUI-BAECHLE-F16S2G3
5 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 26
All Time: 1,867
