Black and Decker Pivot MAX Battery Replacement
  1. Black and Decker Pivot MAX Battery Replacement, Battery: step 1, image 1 of 2 Black and Decker Pivot MAX Battery Replacement, Battery: step 1, image 2 of 2
    • Press in and hold the release button.
    • Rotate the dust filter chamber counter-clockwise.
    • Remove the dust filter chamber.
  2. Black and Decker Pivot MAX Battery Replacement: step 2, image 1 of 1
    • Remove the two 10 mm screws from the motor casing with a Phillips #1 screwdriver.
  3. Black and Decker Pivot MAX Battery Replacement: step 3, image 1 of 1
    • Pull the battery cover up and then slide it away from the motor to remove.
  4. Black and Decker Pivot MAX Battery Replacement: step 4, image 1 of 1
    • Remove the battery unit by pulling it out of the main body.
  5. Black and Decker Pivot MAX Battery Replacement: step 5, image 1 of 1
    • Disconnect the quick connect wire harness that connects the motor and battery located in the battery storage compartment.
25 other people completed this guide.
Jesse Sipes
586 Reputation
2 Guides authored
IUPUI, Team S5-G6, Baechle Fall 2017 Member of IUPUI, Team S5-G6, Baechle Fall 2017
IUPUI-BAECHLE-F17S5G6
3 Members
5 Guides authored
27 Comments
any idea where to find the replacement battery? Does it come as a unit or do you need to disassemble the battery pack and replace the cells?
DMcDermott - Reply
Where do I get the cells to replace the old ones?
Patricia Leat - Reply
How do you disconnect the quick connect
DJ SmashBeatz - Reply
My battery pack is soldered to a circuit board. There is no quick connect. (Model BDH2000PL, Type 2).
HBL - Reply
Same here. Worst design ever.
James Watson -
Past 24 Hours: 24
Past 7 Days: 149
Past 30 Days: 601
All Time: 46,357
