Black and Decker Pivot MAX Power Switch Replacement
  1. Black and Decker Pivot MAX Power Switch Replacement, Battery: step 1, image 1 of 2 Black and Decker Pivot MAX Power Switch Replacement, Battery: step 1, image 2 of 2
    • Press in and hold the release button.
    • Rotate the dust filter chamber counter-clockwise.
    • Remove the dust filter chamber.
  2. Black and Decker Pivot MAX Power Switch Replacement: step 2, image 1 of 1
    • Remove the two 10 mm screws from the motor casing with a Phillips #1 screwdriver.
  3. Black and Decker Pivot MAX Power Switch Replacement: step 3, image 1 of 1
    • Pull the battery cover up and then slide it away from the motor to remove.
  4. Black and Decker Pivot MAX Power Switch Replacement: step 4, image 1 of 1
    • Remove the battery unit by pulling it out of the main body.
  5. Black and Decker Pivot MAX Power Switch Replacement: step 5, image 1 of 1
    • Disconnect the quick connect wire harness that connects the motor and battery located in the battery storage compartment.
  6. Black and Decker Pivot MAX Power Switch Replacement, Pivot Lock Button: step 6, image 1 of 1
    • Remove the handle cover by removing the three PH1 20mm screws
  7. Black and Decker Pivot MAX Power Switch Replacement: step 7, image 1 of 1
    • Pull out the pivot lock button.
  8. Black and Decker Pivot MAX Power Switch Replacement, Power Switch: step 8, image 1 of 3 Black and Decker Pivot MAX Power Switch Replacement, Power Switch: step 8, image 2 of 3 Black and Decker Pivot MAX Power Switch Replacement, Power Switch: step 8, image 3 of 3
    • Lift the battery tray after removing the screws
    • Remove the handle parts from the handle area.
  9. Black and Decker Pivot MAX Power Switch Replacement: step 9, image 1 of 2 Black and Decker Pivot MAX Power Switch Replacement: step 9, image 2 of 2
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 9
All Time: 931
